10-10-2007, 02:05 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
| set screw keeps sliding
I put the metal yokes on the output shafts right on the flat spot when i assembled it. Ablut a week later and ever since, the yoke has play in it allowing it to rotate back and forth across the flat spot. No matter how much I tighten it down yes (threadlock too) the thing slops back and forth whenever I bind or go from forward to reverse and vice versa. Tried a screw in each hole to no avail. IT doesn't rotate around....yet but the output shaft is lookin' nasty! Any solution. Traxxas steel yokes are same as axials but longer pins,not better seating. Solutions???? |
10-10-2007, 02:44 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: NOR*CAL
i put set screws in both sides of each yoke and used thread locker.. hasn't slipped again since |
10-10-2007, 06:54 PM | #3 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| set screws keep slipping
i did the same thing ,but i put long ones in on both sides with lock tight.
10-10-2007, 07:02 PM | #4 |
Pebble Pounder Join Date: Aug 2007 Location: St. Albert - Canada
Are you using a 1.5 hex "driver", or a dinky little "key"? A little key will not tighten the set-screws enough. |
10-10-2007, 07:08 PM | #5 | |
Rock Crawler Join Date: Apr 2007 Location: portland
10-11-2007, 12:41 AM | #6 |
Pebble Pounder Join Date: Sep 2007 Location: Vancouver
10-11-2007, 07:39 AM | #7 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I knew we'd see these problems. Every manufacturer should always include 2 set screws for this, and on the CVD axle joints. Could it be your screw is bad? Can you remove it and try another? Sometimes the threaded can get boogered up and maybe thats why it feels tightened but you still have the slop. I'm also with NinJato...could be the tool used...those cheap "L" allen keys aren't worth much. |
10-11-2007, 07:47 AM | #8 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
10-12-2007, 12:35 AM | #9 |
Here's my take: The "dinky little key" works good for about two uses, then works just OK for about three more, then it's useless. Investing in a good hardened hex driver and you'll wonder how you ever got along without it!
10-12-2007, 08:40 AM | #10 |
Rock Stacker Join Date: Aug 2007 Location: Colorado
I haven't had any problems with my yokes coming off ever since I used thread lock, and a good set of hex drivers are worth every penny |
10-12-2007, 02:14 PM | #11 |
Rock Stacker Join Date: Feb 2006 Location: Brisbane, Australia
No Problems here either, (touch wood, don't want to jinx it now) I did rotate mine backwards and forwards when i was setting the screw, this helps locate it properly on the flat. Brad. |
10-12-2007, 03:09 PM | #12 |
Quarry Creeper Join Date: Sep 2007 Location: Steubenville
Are the link thread studs, the same size as the set screw? I just was thinking.. you could drill the pinion shaft and thread a link stud all the way through the yoke. Never slip again.
10-13-2007, 07:16 AM | #13 |
Sounds like it's time to ditch the crappy keys! lol
10-13-2007, 01:19 PM | #14 |
Newbie Join Date: Dec 2006 Location: The Hague (the Netherlands)
i had the same problem on mine, i didn't use locktight... when i drilled 2 mm deep dimples in the output shafts, both axle and tranny, it locked fine! |
