10-10-2007, 03:21 PM | #1 |
Rock Stacker Join Date: Sep 2005 Location: Oregon City
| Shock cap problem... or not?
I've read of many people having trouble with their shock caps popping off, as well as issues with leaky shocks. The shock caps popping could probably be attributed mostly to too much oil - too much rebound at full compression is just too much for the plastic caps (and bodies) to handle. As far as the leaking issue is concerned - and I may be wrong here - it appears that many of the complaining owner's trucks have the o-ring installed improperly. Unlike Associated shocks, the Axials appear to be designed for the o-ring to be installed INSIDE the caps, not at the base of the threads on the body. I assembled mine the way I'd been building Associated shocks for years, and noticed that the shock cap didn't provide enough pressure for the cap to seal well against the stretched o-ring. I pulled the cap off and viewed a channel inside the cap that looked as though it was designed to retain the o-ring. BINGO! My caps haven't leaked (or popped off) since building the truck. |
10-10-2007, 07:00 PM | #2 |
I joined the Band! Join Date: Aug 2007 Location: mission b.c canada
| shock cap
they are to be installed inside the cap .mine is fine .had no problems
10-10-2007, 07:16 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Yeah I read the instructions right...the O-ring is shown going into the cap... My leak is from the bottom, the 2 o-rings just sit in there not even tightly...weird design. I have stuffed in a traxxas thin white spacer and its holding oil longer...it'll do for now. Got a FatDoggie tuber on order then I'm off to Losi shocks. |
10-11-2007, 12:19 AM | #4 |
Rock Crawler Join Date: Dec 2005 Location: North Vancouver
I think the main problem is people not building them right. I initially didn't do my oring the correct way in the cap and it stripped out my threads a bit, not sure if the oring was the original problem but with the oring in the cap and super glued closed they've been great lol. I think if they are built right they work fine . |
10-11-2007, 08:53 AM | #5 |
Pebble Pounder Join Date: May 2007 Location: "In a van, down by the river!"
No problems with shock caps yet. Broke a front knuckle...swapped with a rear for now. Waiting on aluminum parts... Front knuckle drilled and moved to rear for fix: |
10-11-2007, 01:51 PM | #6 |
Newbie Join Date: Sep 2007 Location: KC
Well, I have to admit, I installed the o-rings wrong (over the threads on the shock body). Now the o-ring is stretched out too far to sit inside the cap. Other than getting new o-rings, any ideas? I guess I'll try to find some that do fit inside the cap. Maybe a local hardware store or something. I've heard of stretching o-rings to fit something, but not shrinking them to fit something! RPS52 |
10-11-2007, 02:02 PM | #7 |
Newbie Join Date: Oct 2007 Location: denver
yea the O-rings are jsut part of a big problem on the design... FIRST OFF the shock caps hits the frame, giving the shocks enough stress that it will almost rip the cap off( if u got oil leaks on top its a sign). second the ti-nitride shafts flexes around 2-4 degrees which causes oil leaks in the bottom of the shock. i think its the piston which is a little loose or small.
10-11-2007, 06:06 PM | #8 |
Well, a quick trip to the local hardware store and I was able to find some new o-rings that fit nicely inside the caps. I haven't put them in yet, but took one of the shock caps with me for a test fit. Anyway, though this was not a huge issue, I think they should have a brief sentence about this in the instructions (for morons like me:-P). That way there's no room for guessing whether the o-ring goes over the shock body threads, or in the cap. Looking back at the instruction manual, all I can see is one small image with what looks like the o-ring inside the cap (side profile). RPS52 |
10-11-2007, 08:06 PM | #9 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
hey If you get AE Green Slime, your shocks wil not leak out the bottom. http://www.hobbypeople.net/gallery/554105.asp |
10-11-2007, 08:29 PM | #10 | |
RPS52 | |
10-12-2007, 04:30 PM | #11 |
Rock Stacker Join Date: Jul 2007 Location: on the rocks
i never had a problem
10-12-2007, 05:34 PM | #12 |
| Yup I tried the same...its the lower 2 o-rings are too loose in that section. I added traxxas thin white washers (I'm sure just about any plastic washers will work depending on thickness) and its way better. Still leaks due to the shaft being able to move at an angle...as mentioned it must be the pistons are narrow or the body is too wide.
10-12-2007, 09:37 PM | #13 |
| leaky shocks
mine leak out the bottom and i also used lots of green slime , my sons arent as bad he also used green slime.
