10-31-2007, 10:26 AM | #1 |
Newbie Join Date: Sep 2007 Location: Hong Kong
| Share my ideas on fixing AX10 shaft.
Here is my ideas, hope you like it. add a 12x18x4mm bearing on the shaft or use a 12mm spacer to fix the shaft failure. |
10-31-2007, 10:38 AM | #2 |
Quarry Creeper Join Date: Sep 2007 Location: No Cajones en El Cajones
Cool idea, but does the outer edge snag on stuff?
10-31-2007, 11:04 AM | #3 |
10-31-2007, 12:04 PM | #4 |
Quarry Creeper Join Date: Sep 2007 Location: Steubenville
Why use a bearing for this? You just put a bearing on there because u had it lying around. Thats silly. Keep your bearings for where they belong.... and anyway, a slick metal bearing isn't going to stay there after dragging it across rocks all day. You gotta get your "bearings" straight man!!! If anything, us a plastic coil isolater around each yoke, and tack it in place in a few spots with super glue. 1. Buy a bag or two or Traxxas Stampede Long half shafts. 2. For your driveshafts, Use TWO female pieces, cut one down about 1/2" shorter. 3. Use ONE male shaft with the yoke removed in the center to join the two females. 4. You should put a small spring (1/2" long) inside each end of the female shafts to keep the male "slipper" in place, centered. 4.Buy 4 Traxxas Stampede metal yokes too. Done. This won't break, pull out or give you any grief. Last edited by Barillms; 10-31-2007 at 12:07 PM. |
10-31-2007, 12:40 PM | #5 | |
Rock Stacker Join Date: Jun 2007 Location: MILAN
10-31-2007, 01:18 PM | #6 |
Quarry Creeper Join Date: Jul 2006 Location: PDX
I had a driveshaft pop off and instead of fooling with it, I just replaced them with Jato shafts. I used the steel pede yokes and drilled the pinion for a through screw instead of the grub screws. Works great so far!
10-31-2007, 01:45 PM | #7 | |
i will try to use super glue to stick the bearing and test run again. | |
10-31-2007, 02:28 PM | #8 |
Rock Stacker Join Date: Jun 2007 Location: Calgary
Good luck with that.
10-31-2007, 03:22 PM | #9 |
A hole in your output shafts is severly weakening the shaft. YOu're removing maybe 40% of the material in one small location making up the bulk of the shaft that is constanly under twisting stain. So now, instead of twisting a yoke, or a shaft, you're going to break a output shaft... and thats definately not good. That's Bad idea #2. The grub screws aren't going anywhere if you have good allen driver, and use lots of locktite. The Jato shafts is good, but drilling.... ahh, no. |
10-31-2007, 03:24 PM | #10 | |
Super glue sticks to oily metal really good... So, definately thats the way to go. If you have any other ideas, PM me. Last edited by Barillms; 10-31-2007 at 03:26 PM. | |
10-31-2007, 03:29 PM | #11 | |
We've drilled holes in the input/output shafts for years. (TLT shafts) The Pede driveshaft gives out before the drilled shaft. Heck, Pede transmissions have their output already drilled from Traxxasssss. | |
10-31-2007, 04:00 PM | #12 | |
Quarry Creeper Join Date: Apr 2005 Location: South Jersey (Cherry Hill area)
10-31-2007, 04:07 PM | #13 | |
Heck, I've stripped all the teeth off of a TLT pinion before breaking the actual pinion shaft. | |
10-31-2007, 06:06 PM | #14 |
Guys, he's talking about super gluing ball bearings to his yokes. Now that's funny. |
10-31-2007, 06:09 PM | #15 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
a bearing is a little big dont you think. you want something low profile so it doesn't get caught on rocks |
10-31-2007, 07:44 PM | #16 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Yeah even a small zip tie is way smaller than that giant bearing. I run a zip tie on the one at the rear axle (only one I popped ever) and still it clears fine.
10-31-2007, 09:05 PM | #17 |
