Thread: Body posts
Old 11-17-2007, 05:20 AM   #1
Unhappy Body posts
Got hooked up on the body posts a fair bit today, so the first thing i did when i got home was re-mount them further up the chassis. (and re-drill the body :-(). This has moved the posts 1" higher. Plus, now they are in the narrower part of the bug body, i can cut them back 1/2". Problem solved.
motormad is offline   Reply With Quote
Old 11-17-2007, 04:03 PM   #2
that was one of the first things i changed on mine
i'm still using the betty body so i have to cut alot out to clear the guards as the posts have to go above the jerry cans
some_guy is offline   Reply With Quote
Old 11-17-2007, 04:53 PM   #3
I did that while building mine. I was told about it, and saw the advantage that it would have at the first comp I went to even before I bought mine.
Rogue is offline   Reply With Quote
Old 11-18-2007, 07:43 PM   #4
Is that an e-savage bug body?? I am trying to decide how to cut the fenders of mine back. Here is a couple pics of my body.
quads4_life is offline   Reply With Quote
Old 11-18-2007, 10:04 PM   #5
That's a top paint job. Shame to hack it. If you want body low with no rubbing i found they needed cutting right back to the body.
Old 11-19-2007, 12:05 AM   #6
This was one of the first things I did to my ax10 because of stength. in the stock location, you can wiggle the body back and forth alot, making it hard to get back on your wheels. whith the mounts higher up, your body has much more strength to it an the truck keeps rollin'. And of course, you dont catch em on the rocks!
mysharona is offline   Reply With Quote
