11-18-2007, 08:19 AM | #1 |
Rock Stacker Join Date: Oct 2007 Location: Devon, UK
| Custom chassis No2
Had this drawn up on SolidWorks for a while, and finally got round to fab up one side this morning using 3mm 6082 T6, (still requires finishing). Have some plans for the link set-up?! The idea was to stand the shocks up a little and make the upper and lower links parallel, and of equal length. It will be alot narrower than the stock chassis, and will use a Delrin skid. Probably use new Axial trans and axles. What do you guys think? |
11-18-2007, 08:40 AM | #2 |
Rock Crawler Join Date: May 2007 Location: Valdosta
I like it, higher shock mounts will drop your ride height. I also heard that longer upper links improve handling, you adressed that also, NICE WORK! Looking forward to a report on the drivability |
11-18-2007, 08:46 AM | #3 |
Longer upper links won't improve handling. They will however keep your pinion out of the dirt on full droop.
11-18-2007, 11:17 AM | #4 |
11-18-2007, 12:33 PM | #5 |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
looks nice.. I think bottom may catch on rock easily .. i would shorten the bottom (lower link area) I'm working on shock mounts as well... I got far as making my electronic tray. lowering the CG Last edited by jmizoguchi; 11-18-2007 at 12:38 PM. |
11-18-2007, 12:36 PM | #6 |
11-18-2007, 12:43 PM | #7 |
11-18-2007, 05:02 PM | #8 | |
Newbie Join Date: Nov 2007 Location: calgary
what kind of shocks are those, im interested about the blue bearing-like upper cap | |
11-18-2007, 06:23 PM | #9 | |
11-18-2007, 07:22 PM | #10 |
11-18-2007, 07:38 PM | #11 |
Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
Resembles Bender's SW3 chassis.
11-18-2007, 08:24 PM | #12 | |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Yes it will, it will help to prevent a certain amount of axle swing in addition to improving pinion angles throughout the range of motion. That's a pretty considerable improvement. Just remember to keep the links you plan on triangulating as parallel to the ground as possible. That chassis should work great. | |
11-19-2007, 10:49 AM | #13 |
11-19-2007, 11:19 AM | #14 |
Got the other side almost finished today. |
11-19-2007, 11:26 AM | #15 |
good looking... did you cut all yourself? |
11-19-2007, 11:30 AM | #16 |
11-19-2007, 11:39 AM | #17 |
11-19-2007, 12:00 PM | #18 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
You should think about selling a couple of your chassis you really did a great job on It. It looks to be thinner witch is always good nice job |
11-19-2007, 12:50 PM | #19 |
Rock Stacker Join Date: Jun 2007 Location: Calgary
What's the width plate to plate?
11-19-2007, 01:25 PM | #20 |
| Thanks for the good comments guys. Don't think it would be cost effective. Probably spent about 5 hours on it allready....as the g/f keeps reminding me, lol. |
