11-20-2007, 06:31 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
| Shock Oil combo
I'm using Traxxas Big Bore Shock. any used 30 weight front and 100 weight in rear? maybe I should ask using 100 weight too much? I haven't got spring set either so that don't help me but wondering someone has tried 100 weight oil |
11-20-2007, 09:38 PM | #2 |
Quarry Creeper Join Date: Aug 2007 Location: tx
I dont know about the BB but with the stock ax I used 50wt all the way around and works really nice.
11-20-2007, 10:37 PM | #3 |
Newbie Join Date: Nov 2007 Location: Seattle, WA
100wt with 2 hole piston and red tmaxx springs is a popular combo locally.
11-21-2007, 12:13 AM | #4 |
Quarry Creeper Join Date: Aug 2005 Location: Tucson
100wt for all four shocks great combo |
11-21-2007, 12:59 AM | #5 |
Pebble Pounder Join Date: Apr 2007 Location: parked in a handicap spot
i like running 25wt in the front and 30wt in right rear and 35 in left rear. soft springs up front and med on right rear and a traxxas stampede front spring on the left rear with some preload spacers to compensate for the shortness of the spring.
11-21-2007, 01:07 AM | #6 |
Rock Stacker Join Date: Oct 2007 Location: Taranaki
I have been using 20wt front and rear with Mini T springs inside the shock. Seems to work fine. What will heavier oil do?
11-21-2007, 01:25 AM | #7 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Shock oil changes how fast they react to the terrain. I run 15 or 20 all the way around on stock shocks.
11-21-2007, 01:25 AM | #8 |
I'm running the same Traxxas Big Bore shock as you, with the stock springs that come with them, but with 60 wt all around. I plan to go a little thicker but probably not all the way up to 100 wt. |
11-21-2007, 08:59 AM | #9 |
Thanks guys.. I need to test to see what I like.. |
