11-23-2007, 03:24 PM | #1 |
Rock Stacker Join Date: Aug 2007 Location: Kingston
| Anyone experienced this?
IM on my 2nd scorpion build and I either did something wrong or something isnt machined right... The truck is built but something just doesnt feel right in it...It feels all stiff and such. When I mounted the shocks on the truck at the top as I was screwing it together, I could see that part of the chassis flexing inwards towards each other....I dont recall my original scorpion being like that. Then when I went to mount the battery tray, The guide pins and screw holes wouldnt line up, I had to undo the plastic piece where it mounts on the top of the chassis, assemble the battery tray then force it all together and re screw it... It almost seems as though my skid plate is too wide and my 2 side chassis plates are too long or something. Ive checked, rechecked and triple checked my assembly and it all appears right according to the directions... Is anyone elses truck that tight? Im definately thinking I missed something somewhere but I just cant put my finger on it. |
11-23-2007, 03:34 PM | #2 |
Newbie Join Date: Sep 2007 Location: Jacksonville
If you have a dial caliper you can do some quick checking between the two to see what , if anything, is different. Mofroggy |
11-23-2007, 04:12 PM | #3 |
11-23-2007, 06:19 PM | #4 |
Got it figured out...Turns out I had the wrong pivot ball thing in the top of the shocks...I had used the plastic ones in the kit rather than the steel ones...I was half asleep I guess during that part of assembly. |
11-23-2007, 10:18 PM | #5 | |
There are plastic ones? I guess I never saw those. But I only took out the parts called for | |
11-24-2007, 05:38 AM | #6 |
| Ya I had a set of big bores all set up and mounted on....But was wanting to try something with the stock ones and in my hurry to build them didnt bother with the instructions and just grab the plastic ones I saw...My fault.. |
