11-25-2007, 09:02 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Elizabethtown,KY
| 12MM Hex Hub Adapter
Hey guys.. I just got RC4WD wheel and came up with some issue with using stock 12MM Hex hub (green). it will not seat correctly. I'm still planning to use stock wheel to so looking my option for replacing with different one. I know Tower hobbies is selling same one for $17. I could mod that to fit or also get 12mm.12mm wheel widen adapter for TLT that RC4WD sells. Even that I have to mod the adapter fit right. Can someone give me some idea on parts chocies? |
11-26-2007, 12:55 AM | #2 |
Newbie Join Date: Oct 2007 Location: Rocklin
I noticed the same thing w/ my RC4WD wheels. I knew the alum. hexes weren't coming out if they did seat. So I used the plastic hexes that also came w/ the kit. And just leave them in there. No problems yet.
11-26-2007, 02:29 AM | #3 |
Rock Stacker Join Date: Oct 2007 Location: I found Dorothy
I had the same problem with mine from RC4WD, I sanded them down on each side (green hexes) they fit great and come off easy. I used a dremel sanding wheel.
11-26-2007, 03:13 AM | #4 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Grab a file |
