12-04-2007, 06:44 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: New Zealand
| Upside down shocks ?
I see alot of rigs running their shocks upside down, what is the reason for this and how do the compare to say running the shocks the right way up ? I know this is not a specific AX10 question but I have seen a couple like this so far.
12-04-2007, 06:47 PM | #2 |
Pebble Pounder Join Date: Jul 2007 Location: Okinawa, JP
easier to switch out springs |
12-04-2007, 06:51 PM | #3 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
lowers the COG abit |
12-04-2007, 07:41 PM | #4 |
12-04-2007, 07:59 PM | #5 |
RCC Addict Join Date: May 2005 Location: Utah
To try and bring excess weight below the top of the tire. That oil is very minimal weight up there...
12-04-2007, 08:08 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
You do it to keep your shock oil full of air.
12-04-2007, 09:10 PM | #7 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
12-04-2007, 09:27 PM | #8 |
Quarry Creeper Join Date: Mar 2006 Location: Eastern North Carolina
Having the shock body lower, lowers the CG. I found that the stock shocks didn't work well (binding) upside down on AX10. Since the shocks are plastic, it's no big deal anyway.
12-05-2007, 01:12 AM | #9 |
To be sure I'm not just overlooking something.. Air bubbles would cause inconsistencies in shock stroke.. or ?? And what exactly is changed by flipping the shock? Also would internal springs make any diff either way??
12-05-2007, 01:23 AM | #10 |
Pebble Pounder Join Date: Sep 2007 Location: Vancouver
The stock Scorpion shocks are "emulsion" type. Emulsion dampers require the shock oil to be full of air. No air? No volume compensation...
12-05-2007, 01:27 AM | #11 |
so are big bores different?? Is it even a bad thing... now I'm just lost Last edited by stanbro; 12-05-2007 at 01:30 AM. |
12-05-2007, 01:40 AM | #12 |
Big bores have a bladder to keep the air and oil separated. But for a crawler, at the sloooow shocks speeds... I don't think it really makes much difference. I run mine upside down... and I've used both the Axial and the Big Bores. I ended up back with the Axial's mostly because of the ball at both ends of the shock. The Big Bores need to use a small piece of fuel tubing at one end. |
12-05-2007, 06:31 AM | #13 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
12-05-2007, 07:05 AM | #14 | |
HUH???? I have been in R/C for over 13 years and never heard that. This was quoted from a site that I will also link to...... Some shocks are made to be mounted "upside down", with the oil chamber and piston on top. Since the piston and oil chamber move independently, it's best to attach the light portion - the piston - to the wheel and the heavy portion - the oil chamber - to the frame. This decreases the unsprung weight. However, many people think it looks weird. You cannot just turn any shock over - most shocks have air and oil in them, and the oil level will be wrong if you mount them upside down. http://www.calsci.com/motorcycleinfo/Suspension.html Yes, I know its a motorcycle site. Ok, first, they use nitrogen. Nitrogen and oil is very hard to mix. Oxygen on the other had will mix easy. Is there a write up on this some where guys? Not saying that you are wrong but I have never heard that. | |
12-05-2007, 09:12 AM | #15 |
Wow link to a motorcycle site, even frigging motorcycles use inverted and traditional front forks all the time. I own a mototrcycle and know for a fact that their entire piston and valving system does not in anyway relate to the theory of our shocks as we use shocks that are far more simplistic. Time to think about Emulsion and Bladder shocks. If you've been in the RC world for years you should completely understand how the Bladder shock (think TMAXX) works compared to a Emulsion (think Losi 1/10th scale). Also you mention Oil and Nitrogen are hard to mix, agreed, but then you go on saying Oxygen and oil are better. Do you fill your shocks with only oxygen or do you use standard everyday Air? Last time I checked the scientific world has proven that "Air" is comprised of 78% Nitrogen, 20% Oxygen, the rest being argon, carbon dioxide and trace elements in gaseous state. Obviously depending upon humidity you will also find some water vapor in the mix as well. Here is a great link on the difference with pictures and explanations of the RC world and its shock types: http://www.rc411.com/pages/howto.php?howto=31&page=2 |
12-05-2007, 09:25 AM | #16 |
12-05-2007, 10:09 AM | #17 |
| You leave a wise crack comment all the time yet never offered the user help. Especially when the wise crack comment isn't correct. If you don't want to help newbies or people below your level, don't click the "Submit Reply" button. Last edited by binaryterror; 12-05-2007 at 10:12 AM. |
12-05-2007, 11:50 AM | #18 | |
12-05-2007, 11:52 AM | #19 | ||||||
AFAIK, all other types of shocks have the oil and volume compensation gas (air, nitrogen, whatever) physically separated. In 'Maxx shocks, it's a flexible bladder; in others it's a floating piston. Orientation should have no effect on performance for these kind of shocks. Quote:
For one more, here's an article reproduced from RC Car Action mag: Quote:
12-05-2007, 12:23 PM | #20 | |
I help people all the time, what I said makes perfect sence. Sometimes people need to help themselves, this is at least the 7th time in the last month this question has been asked. | |
