12-24-2007, 11:01 AM | #1 |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
| Rear steer for $35??
WTFBBQ?? 2 links (yea they're nice), a servo saver that I'm not gonna use, and a jiggly servo horn that I'm not gonna use, for 1/6 the price of the whole kit? $35?? Am I missing something??? Guess green anodizing must be a spendy process. |
12-24-2007, 11:17 AM | #2 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
if you want rear steer, just get an extra servo ( you might already have one). The ax 10 kit comes with 2 axle plate/servo mounts,... i just used 6-32 rod, then sleeved it with 3/16 brake line, i used the build manual and made them the same length as the front linkage... and WALA... rear steer....
12-24-2007, 01:48 PM | #3 | |
12-24-2007, 03:08 PM | #4 |
Rock Stacker Join Date: Dec 2007 Location: toledo area
4-40 is to small you will yank out the threads quickly I would step up to 6-32
12-24-2007, 03:11 PM | #5 |
3/16 brake line has a good inside diameter for 6/32 you can run a tap in the ends for a tie rod link. There is a thread about making links. its a sticky somewhere about it. |
12-24-2007, 03:13 PM | #6 |
12-24-2007, 03:29 PM | #7 |
Thanks man. Since I already have em I'll give the 4-40 rods a shot. If I strip em out I'll step up. As far as the brake line goes, isn't that stuff supposed to be relatively flexible? |
12-24-2007, 03:30 PM | #8 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
Just making sure your not planning on running in any comps? 4ws is not allowed for competition use, in the 2.2 class.
12-24-2007, 03:38 PM | #9 | |
heh... really the main reason I want rear steer is because of all the work I put into my controller. My Modded TQ3 Update - Added EPA pots After all that it'd be lame not to use it. | |
12-24-2007, 11:10 PM | #10 |
Rock Crawler Join Date: May 2007 Location: lacey
because your allowed to use reverse, where the opposite is true for supers, no reverse, ok on rear steer. silly huh?
12-24-2007, 11:37 PM | #11 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
12-24-2007, 11:46 PM | #12 | |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Dig setups are allowed in comps and pretty much everyone and their brother is running one now a days. Last edited by Mnster; 12-24-2007 at 11:49 PM. | |
12-25-2007, 12:07 AM | #13 |
hmm... well for now since I'm just screwing around I'll have rear steer. Take me all of 5 minutes to remove if necessary. I'm very interested in dig but I need to lear more about it. Seems like there were a lot of changes during my break from crawling.
12-25-2007, 07:03 PM | #14 |
when i did my rear steer on the AX10, i just used the extra rod ends in the kit ( the straight ones) and then bent my tie rod out a little to clear the diff
