Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: bmuzz1's 2008 Comp Rig
Old 01-04-2008, 07:34 PM   #1
Building again
bmuzz1's Avatar
Default My 2008 P.A.R.C. Comp Rig
I just completed an extensive reconstruction of my AX-10 for the upcoming P.A.R.C. comp season.
Here is a list of parts and suppliers used to complete my re-build.
TCS Tranny skid
TCS High clearance links
TCS Aluminum upper link/servo mount
TCS Aluminum Boomerang
TCS Aluminum axle plates
TCS 8cell split battery pack
Integy alloy main chassis from TCS
Integy MSR10 shocks from RPP
RC4WD Aluminum Knuckles and C's from TCS
RC4WD Straight axle adaptor and Axles
Imex Rubicons (soft) from TCS
Hot-Racing wheels from CKRCCrawler
Hitec 5645 servo from TCS
Rooster Crawler/Fiftyfive combo from RCP
Airtronics MX-3S radio from Hobby People
And last but not least dig set-up using design by Miniwheeler.
Thanks to all the great friends, posts and vendors that made this build possible.
Name:  2008 PARC Comp Rig001.jpg
Name:  2008 PARC Comp Rig002.jpg
Name:  2008 PARC Comp Rig005.jpg
Name:  2008 PARC Comp Rig003.jpg
Name:  2008 PARC Comp Rig004.jpg
Name:  2008 PARC Comp Rig006.jpg
bmuzz1 is offline   Reply With Quote
Old 01-04-2008, 07:49 PM   #2
Nice build. I dig the chassis. IT looks like only 1 hole for the upper links to mount in the chassis, is that what I'm seeing?
solomon7 is offline   Reply With Quote
Old 01-04-2008, 08:05 PM   #3
Building again
bmuzz1's Avatar
Thanks...It actually has 11 holes to mount the upper links to...6 holes in the lower stock point where I have mine mounted and 5 in the back position where a lot of guys have been drilling holes in the stock chassis.
Old 01-04-2008, 08:14 PM   #4
How do you like those shocks so far?
2JSC is offline   Reply With Quote
Old 01-04-2008, 08:17 PM   #5
Foot in Mouth! I should've seen that. It helps to liik more than once I guess.
Old 01-04-2008, 08:46 PM   #6
Building again
bmuzz1's Avatar
They are the strongest and smoothest shocks I have ran.
Old 01-04-2008, 11:44 PM   #7
That's a nice looking rig!!! Doesn't look like it had hit the rocks yet from the pics.
freestyle is offline   Reply With Quote
Old 01-04-2008, 11:52 PM   #8
SWEET chassis.
Bansheeboy11 is offline   Reply With Quote
Old 01-05-2008, 09:34 PM   #9
Building again
bmuzz1's Avatar
Thanks! I had just got the chassis in the mail from TCS the same day I took the picture so it hadn't.
Old 01-05-2008, 09:38 PM   #10
Building again
bmuzz1's Avatar
Originally Posted by Bansheeboy11 View Post
SWEET chassis.
Thanks...It is an awesome chassis!
Old 01-06-2008, 10:04 AM   #11
looks like P.A.R.C better watch out for you this year that chassis looks very tunable ,good work on the DIG set up deffently my next mod
BlazinKreeper is offline   Reply With Quote
Old 01-06-2008, 10:41 PM   #12
Building again
bmuzz1's Avatar
Thanks again. We'll see...This will only be my second season so I've still got a lot to learn.
Old 01-07-2008, 11:59 PM   #13
If you guys have not seen these shocks in person...They are BEEF! Those shafts are massive...very smooth also...I must agree.
Jonnie Fraz is offline   Reply With Quote
Old 01-08-2008, 12:56 AM   #14
bmuzz1 are you running any oil in your integy shocks, and are you using the stock springs? i've got a set but just haven't got around to using them
ScorpioCrawler is offline   Reply With Quote
Old 01-08-2008, 08:23 AM   #15
are those hot racing beadlocks wider than the stock ax10 wheels?
mickrcarver is offline   Reply With Quote
Old 01-08-2008, 02:31 PM   #16
Building again
bmuzz1's Avatar
I am running the stock heavy springs with 30wt oil in all but the left rear which I am running 80wt in to help with tork twist.
Old 01-08-2008, 02:33 PM   #17
Building again
bmuzz1's Avatar
They are the same width but the off-set gives you 1/2" more track width.
Old 01-08-2008, 03:54 PM   #18
did u have to drill any holes in the bottom piston? I tried running oil in mine and they wouldn't compress
Old 01-08-2008, 07:07 PM   #19
Building again
bmuzz1's Avatar
I filled the shocks up to the second from last spring and that seemed to work fine.
Old 01-29-2008, 04:25 PM   #20
Building again
bmuzz1's Avatar
Had to make a few changes to the truck after some testing. The new Cirrus 190oz servo was getting too hot so switched it out for a Hitec 5645mg. I also replaced the Novak XRS esc and Inetgy 55 lathe motor with the Novak Rooster Crawler and FiftyFive motor combo. Works much better now.
TCS Tranny skid
Cirrus 190oz. steering servo from Hobby People
Attachment 52791
Attachment 52792
Attachment 52793
Attachment 52794
Attachment 52795
Attachment 52796
