Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Axial AX-10 Scorpion
Thread: Axial SW3 R2D
Old 01-05-2008, 01:43 PM   #1
Default Axial SW3 R2D
Hi Guys - need some help please ( I think )
I have my AX10 part built here and a SW3 chassis in the post and a R2D in another package in the post.
I just looked at the pictures on the net again of the tranny and notice the output shafts have holes drilled through them ???? So how are my Axial driveshafts going to fit on there then ? - is it as simple as just using long grub screws ? surely not
TIA
RaceChat is offline   Reply With Quote
Old 01-05-2008, 02:30 PM   #2
I beleive so...
balang_479 is offline   Reply With Quote
Old 01-05-2008, 03:41 PM   #3
cato's Avatar
racechat: I'ld recommend ya drill the holes..I used the maxx-shafts and even running two set screws, had bad luck trying to keep on or even centered for that matter.
cato is offline   Reply With Quote
Old 01-05-2008, 04:24 PM   #4
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
The shafts are already drilled, that was the point of his post.
I use an extra long set screw, similar to a max shaft pin. You can get them at Ace hardware in the set screw bins, they are about 30 cents each.
Harley is offline   Reply With Quote
Old 01-06-2008, 02:20 AM   #5
Thanks for the replies - a long set screw it is then I think.
I'm assuming the hole is 3mm then ? (like I said my tranny isn't here yet)
