| | #1 |
| Newbie Join Date: Nov 2007 Location: Wallace
| do bent links up front help approach? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Sep 2007 Location: KC
| They really don't help approach, but I think they would come into play when you get your front tires up and over an obstacle, like a log or a ledge or something like that. The goal is to keep the tires in contact with the ground, so they can propel the truck. RPS52 |
| | #3 |
| Rock Stacker Join Date: Nov 2007 Location: Billings
| NO the bent links dont help approach angle they only help with ground clearance. your approach angle is determined by what point your tires contact given obstacle. A 90* approach is if your tires hit before anything else. Take a shoe box or something else that is 90* if your tires hit before the drag link or tie rod you have a 90* approach. If not take a protactor or angle finder and determine what that number might be. Your body or bumers if you have them might be a hindering factor in approach angle. You can also determinr your departure angle the same way. Both are improtant in rc as well as 1:1 |
| | #4 |
| I wanna be Dave Join Date: May 2006 Location: AZ - In The 928
| The bent links really onlt help with breakover angles. |
| | #5 |
| Rock Crawler ![]() Join Date: Aug 2007 Location: oak harbor
| I run bent links front and rear. I agree they do not help break over but they do seem to really work well for ground clearance. I would recommend trying the front and rear. |
| | #6 |
| Cool thanks. I have bents in the rear and they do help for clearance. Ive been thinking of going to super softs in the rear also, they seemed to help up front. I read somewhere in this forum that bents in the front make your chassis stuff onto an obstacle so I was wondering if anyone has had that problem. |
| | #7 | |
| Perpetual Newbie ![]() Join Date: Oct 2007 Location: Kennewick, Washington
| Thread Tools | |
| Display Modes | |
