Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: here's my deadbolt
Old 04-17-2014, 08:45 AM   #1
Default here's my deadbolt
heres a picture of my deadbolt:
i've only done a few upgrades so far.
-35t Integy matrix motor w/18t pinion.
-Solar D772 servo w/hot racing aluminum links and Axial horn.
-flipped lower shock mounts
-Chevy Silverado hacked up body
-AMF front and rear diff guards
-2 1/4 oz in each front wheel
-custom cut trepadors (pictures before cutting and with stock servo)
StraightCreepin87 is offline   Reply With Quote
Old 04-17-2014, 11:13 AM   #2
Default Re: here's my deadbolt
I dig the body! Looks great
redsawacs is offline   Reply With Quote
Old 04-17-2014, 01:55 PM   #3
Rig is looking great!
Pull the trans and locktite the three slipper screws...I have heard it a bunch of times so I did it.
And there was no locktite.
I did most of the same tweaks as you.mount swap etc 55t motor(should have gone 35)
I swapped the batt tray to the front
Added a bec to run my turnigy 767 mg servo at 7.4v.Dremaled the tires to try and improve them before replacing them.still going to upgrade steering parts though the plastic is too flexy for me.
Sent using lipo power
jaymann is offline   Reply With Quote
Old 04-18-2014, 12:11 PM   #4
i indeed pulled the trans and gave her some loctite. i also cut my tires to some suitable traction for now. i have the axial 103mm aluminum shocks i am awaiting oil for to be installed. yeahthat was the first thing did was got rid of the junk plastic steering linkage and replaced it with the aluminum linkage and servo horn. nice looking picture of your ride. thanks for the share
Old 04-18-2014, 12:52 PM   #5
Well I couldn't stop myself...lol gained a inch of width.proline Titus beadlocs and 2.2 swampers in g8
They feel much better.
It's a shame the trepadors look really good but are just not grippy enough for me.
Old 04-19-2014, 09:46 AM   #6
Thanks for posting your pictures and sharing your experience with the tires. I ran my Deadbolt for the first time last night and was ultra disappointed with the stock tires. They have to go immediately. I couldn't imgagine in my wildest dreams that those tires would perform so poorly.
43YrOldRCFan is offline   Reply With Quote
Old 04-19-2014, 10:21 AM   #7
Just played in the yard for a few minutes. Tires made a big improvement added about 4.5 oz to each front wheel.The swampers are far softer and stickier than the trepadors going to carve them (Trepadors)up more see if they can be made to grip better.
Old 04-22-2014, 09:46 PM   #8
First try at making links and such
Old 04-23-2014, 06:45 PM   #9
Natedog's Avatar
Extra width is not what these axles need. Get the snippers and Dremel out and start siping and modding the Trepadors. Some good beadlocks and CI foams for tuning will do a lot for you.
here's my deadbolt - Similar Threads
for those with deadbolt and trepadors StraightCreepin87 Axial AX10 2nd-gen 3 05-09-2014 09:05 AM
My new Deadbolt 05stroker Axial AX10 2nd-gen 17 02-17-2014 06:14 PM
Deadbolt Alamo71 Axial AX10 2nd-gen 2 12-24-2013 01:43 PM
