01-19-2015, 04:11 PM | #1 |
Newbie Join Date: Jan 2015 Location: Blue springs
| Battery tray help!!
I've got the ax10 deadbolt. Moved the battery tray forward and have used weather striping in the bottom of the tray to keep the battery from sliding out. It helps but it still slides out any tips or tricks to keep it firmly planted would be appreciated. I'm using a hard pack lipo.
01-19-2015, 09:22 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: Hamilton, Ontario, Canada
| Re: Battery tray help!!
The Strap is not holding it in place?
01-20-2015, 08:40 AM | #3 |
Nope. I might try and rig up another strap.
01-30-2015, 09:31 AM | #4 |
Pebble Pounder Join Date: Aug 2014 Location: King George, VA
I'm not sure why you are having an issue, the strap works great. Did the strap move? Are you strapping it tight enough? You could always just use a small piece of Velcro on the bottom of your tray and the other piece on the battery. It wouldn't take too much. |
01-30-2015, 09:35 AM | #5 |
RCC Addict Join Date: Apr 2009 Location: LA
Yup, Velcro with the strap is what I use.
01-30-2015, 11:43 AM | #6 |
The Velcro strap is tight but the problem is when it takes a tumble the battery slides back into the esc. I've used rubber weather strips in the bottom of the tray and it seams to help. I've added another strap so next time out I hope it holds better. Thanks guys.
01-30-2015, 09:50 PM | #7 |
Sorry, I wasn't very clear. In addition to the Velcro strap, I put adhesive-backed Velcro on the battery and tray where you put the weather stripping.
01-31-2015, 10:31 PM | #8 |
Yeah that happens. Put a piece of velcro in the tray and the other side on the battery. |
01-31-2015, 11:24 PM | #9 |
| Re: Battery tray help!! |
02-02-2015, 08:17 AM | #10 |
Will do guys. Thanks for the help.
Battery tray help!! - Similar Threads | ||||
Battery tray & battery options? | Mysterious | Axial XR10 | 10 | 02-18-2012 01:13 PM |
Battery tray... | artsifrtsi | Team Losi Comp Crawler | 3 | 01-03-2010 09:55 AM |
new battery tray | kazi | Axial AX-10 Scorpion | 24 | 03-24-2008 07:18 PM |
Battery Tray? | bemmermazda | General Scale Talk | 0 | 06-29-2007 05:35 PM |
