Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: 5Th Dimension Sucker Punch "The Green Machine"
Old 06-18-2015, 11:16 PM   #1
Default 5Th Dimension Sucker Punch "The Green Machine"
5Th Dimension Sucker Punch... My "The Green Machine"
Decided to use my U4RC wraith as a donor rig to build another sporty rig, with nationals coming up & hopefully help grow our local club 2.2s class (BLC). So, of course I got in touch w/ 5th Dimension in hopes of getting my hands on another Sucker Punch chassis. My 1st SP rig simply worked SUPERBLY... (I REALLY miss that rig).
A few weeks later I was fortunate enough to receive this great chassis in the mail. Chassis came pre-assembled & packed very well. Getting the chassis pre-assembled is NICE added touch.
If interested you can pick up a 5D Sucker Punch chassis link below.
You can even pick color of choice
"NEW" The 5th Dimension "Sucker Punch" sporty/shafty chassis
Cboggs posted some nice pictures of this chassis, however pics certainly don't do this beauty justice...looking absolutely stunning in person.
5D did a killer job updating this chassis by milling pockets in the skid to lighten it. The skid link mount pockets have a very tight fit with 2 new hex style cross braces for you body mounts.
tapped-out is offline   Reply With Quote
Old 06-19-2015, 12:12 AM   #2
5th D Owner/Driver
cboggs's Avatar
Default Re: 5Th Dimension Sucker Punch "The Green Machine"
I can't wait to see the "green machine" built up!
cboggs is offline   Reply With Quote
Old 06-19-2015, 07:28 AM   #3
Thanks for the writeup so far. Looking forward as well to what ya come up with. Hit me up if ya need anything to keep the green machine well...green.
KingGee is offline   Reply With Quote
Old 06-19-2015, 09:32 AM   #4
The green looks great! Good to see another Sucker Punch out there! Looking forward to seeing The Green Machines build-up!
mammoth is offline   Reply With Quote
Old 06-19-2015, 10:24 AM   #5
Thanks guys,
So, with this build I'm trying to use parts I have or can buy used/cheap. Digging in my parts box found these links rears bolted up no problem @ all. The front lower links took a little more work, I had to put 2 bends in each link to keep them from binding. I need to make/buy front upper links.
Axles on the rig are Ar60's OD/UD axial gears, D-lux servo mount, W/7950 servo & VP scale knuckles & chubs. Axles came off my U4RC Wraith....
Old 06-19-2015, 11:34 AM   #6
Y-Town Crawlers
Del Monte's Avatar
COOL!! More sportys for next season!!
I'll have to bring mine out of retirement, and build a 2.2S tank for Jess to drive
Del Monte is offline   Reply With Quote
Old 06-19-2015, 04:13 PM   #7
Looking good.
Dezertdirt is offline   Reply With Quote
Old 06-20-2015, 01:00 AM   #8
Like most using AR60 axles I was worried about them being to wide. So I spent some time on my rear axle today using XR10 plastic lockouts & modding the inner axle shafts. I cut 9mm off the tang & filed new flat spots into axles to fit into locker. It was an easy cheap way to shave 18mm off the rear axle.
with this mod in combination with DE wheels and RC4wd hubs (not pin style).
rear width is a hair over 10" outside to outside of tires.
Before
After
This show the difference between the Wraith & XR10 locker
WOW... this Wraith Trans is a pig. It has all steel gears with a team Brood
30T Conflux motor BIG THANKS to my buddy D-wray for hooking me up with this motor.
Old 06-20-2015, 02:03 PM   #9
It's a roller..... specs below..
titanium links
AR60 axles
front D-lux servo mount, Hitec 7950 servo, VP scale knuckles & chubs.
rear XR10 mod to narrow axles.
Wraith trans all steel gears 56t spur/10t pinion it's a heavy MOFO.
Team Brood Conflux 30T motor
2.2 DE wheels modded to fit RC4wd hubs W/ rovers & CI DD foams.
ESC side Winder Micro, CC BEC, Futaba receiver
SCX10 shocks with mini-t springs.
Rig weight is 4.087 as pictured
Need to mount electronics, body mounts & cut/paint the body.
Old 06-21-2015, 01:01 PM   #10
Lacking fab skills I made this electronic tray.
Old 06-22-2015, 08:14 AM   #11
It's alive! Did a little couch crawling yesterday.. I managed to get esc,receiver, bec & a nest if wires on the mounting plate. I'll eventually shorten servo wires.
Old 06-23-2015, 05:12 PM   #12
I went with transparent Green basic rattle can paint job. I was hoping paint job was going to be more see-thru to show off the green Sucker Punch chassis. Looking forward to getting some drive time on this new rig.
Old 06-23-2015, 07:00 PM   #13
I think you have the front rovers on backwards, but other than that it looks great. What is the rtr weight?
Old 06-23-2015, 07:56 PM   #14
5th D Owner/Driver
cboggs's Avatar
Came out good, nice job on the build.
Old 06-23-2015, 07:57 PM   #15
Thanks, that's how I run my rover's. It's a pig 4.411lbs. Looking @ pictures again looks like my rear rovers are backwards... good eye.
Old 07-01-2015, 09:03 PM   #16
So I have an older sucker punch chassis in black, what is the difference with the new ones? Just the color? Material? They look very similar...
Turtlejon is offline   Reply With Quote
Old 07-01-2015, 09:31 PM   #17
5D did a killer job updating this chassis by milling pockets in the skid to lighten it. The skid link mount pockets have a very tight fit*with 2 new hex style cross braces for you body mounts. & yes you can pick different color combos.
Old 07-01-2015, 11:14 PM   #18
5th D Owner/Driver
cboggs's Avatar
Matt nailed it, same great chassis with a few updated improvements.
Old 07-02-2015, 03:21 PM   #19
Awesome! Thanks for the info!
Old 07-14-2015, 05:12 PM   #20
Working on going bodiless:
5Th Dimension Sucker Punch "The Green Machine" - Similar Threads
"NEW" The 5th Dimension "Sucker Punch" sporty/shafty chassis cboggs Chassis and Suspension 58 07-11-2018 04:21 AM
