Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: Who has the best ax10?
Old 07-21-2015, 05:17 PM   #1
Default Who has the best ax10?
Post pictures if you think you have the best ax10.
The_Know_It_All is offline   Reply With Quote
Old 07-21-2015, 06:00 PM   #2
Default Re: Who has the best ax10?
AngelowDoom is offline   Reply With Quote
Old 07-21-2015, 06:16 PM   #3
It's a discontinued HPI savage body
https://youtu.be/8imEWyNesJ0
Old 07-21-2015, 08:24 PM   #4
I have the best ax10 sporty rig, jk. That quad is really cool.
tapped-out is offline   Reply With Quote
Old 07-21-2015, 08:37 PM   #5
Have to trim the body at all or anything to get it on?
Old 07-21-2015, 09:54 PM   #6
Why's no one commenting
Old 07-22-2015, 12:15 AM   #7
No trimming was needed, but had to make my own body mounts
Old 07-22-2015, 12:31 AM   #8
Ok what did you make the mounts out of was wondering if I could possibly find one.
Old 07-22-2015, 05:54 AM   #9
It has it's own thread. You can see it there, but basically a nylon plate with ax10 gen1 bodyposts screwed on to it.
The adventures of Stuntman Steve
Old 07-22-2015, 09:37 AM   #10
Shouldn't you already know?
travis c. is offline   Reply With Quote
Old 07-22-2015, 10:39 AM   #11
This is my ax10 who I like the best regarding looks, but I have 2 more gen 2 who is better performers crawling wise, and 2 more ax10 gen1 scorpions converted to sportsman rigs who outperforms them all on the rocks. But in the trail I like best the ATV cus it looks more like a real one. So more fun to drive in trail. But on the rocks the sportys are more fun. depends what kind of rig you are looking for when u ask for the best. But since u posted in gen2 section I assumed it was more trail ax10 you was after, since that platform is more popular for trail and bashing than the rocks. Even though you can also make them into very good rock rigs. Hope more people can contribute with cool ax10 builds, cus ax10 is one of the most fun rigs out there.
Old 07-28-2015, 10:29 AM   #12
coldfire is offline   Reply With Quote
Old 07-31-2015, 12:38 PM   #13
AX10 Deatbolt
-Futaba servo/ sealed w/ aluminum horn
-Gmade Zero Shocks
-Axial aluminum links
-RC4WD aluminum steering
-35T crawler motor
-RC4WD Mickey Thompson 2.2 steel beadlocks
-Mickey Thompson Baja Claw Tires (super sticky compound) / "trimmed" foams
-Vanquish C hubs, spindles and lock outs
-Axial Universals
-Battery moved over servo
-XR10 body with a Desert Camo paint job
Overdriving the front diff hopefully this weekend if the parts are on the shelf.
tarpon4me is offline   Reply With Quote
Old 07-31-2015, 12:39 PM   #14
Did that jeep body accept the Deadbolt cage?
Old 08-01-2015, 05:48 PM   #15
I wouldn't say it's the best, but I think it did look cool, although a little top heavy with the hardbody on it. Had to use longer rear links to get the rear axle to line up with the rear fender openings. Second pic is what it looked like without the bed on, and with stock links.
Mike Flea is offline   Reply With Quote
Old 08-04-2015, 08:15 PM   #16
I don't but it's fun
josh6575 is offline   Reply With Quote
Old 08-08-2015, 12:10 AM   #17
Hi Folks, I do sooooooooooo Love my Ridgecrest, I cant post pics so here is a link to my build in the German forum; Ridge-Mog - 4x4 Scaler 2,2" und grösser - Rockcrawler.de Its now running a absima servo and a robbe esc with a 21.5t brushless skyrc motor, with the rtr radio, I have done the wroncho build from Harley Designs ( A GREAT how-to there folks) with a 406 unimog body, shocks are xr10's with a limiting spring on the inside so they ride @ 90mm and extend to over 100mm the body mount is a abs plate cut to fit the body lines ( helps keep the body from deforming) the rims are who knows what got them from a guy over here,, This weekend there will be a external bec installed ( 8-15amp @ 6volt) and the switch from 2s to 3s.
Those Rigs above are HOT, I am happy to be on the same page as them!!!
Phatz is offline   Reply With Quote
Old 08-08-2015, 01:16 PM   #18
That did turn out nice Phatz, but I don't know if it's still classified as an AX-10, however, it IS a real nice Wroncho, I like the paint job,
Old 08-08-2015, 02:30 PM   #19
Thanks Mike, I really do love that Rig, everybody keeps saying that my Mog is no challenge to drive, but I did put alot of time in setting this Beast up, and now yeah it ROCKS, and personally it makes it alot of fun to drive!!
And thanks again!!
Old 11-28-2015, 05:30 AM   #20
Not the best by any means, but I sure do like it! Started as a Ridgecrest, not sure what it is anymore.
Creepcreep is offline   Reply With Quote
Who has the best ax10? - Similar Threads
Axial Scorpion AX10 Axle Give-A-Way **Free AX10 Axles*** Rockpiledriver Axial AX-10 Scorpion 297 08-27-2007 06:15 AM
