Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: Vanquish Incision Wraith 1/4" stainless link kit
Old 03-02-2017, 08:41 AM   #1
Default Vanquish Incision Wraith 1/4" stainless link kit
I was planning on purchasing the Incision Wraith link kit for my AX10 Deadbolt. (Tired of the cheap plastic ball ends on the Aluminum Axial links) Anyway, I looked around here and it sounds like people have done it. My question is, due to the Wraiths longer wheelbase and skidplate, will I need to get extended length outputs to make up for driveshaft length? I'm running JunFac's specific to the AX10 right now. Any info is appreciated - Thanks!
mewalsh100 is offline   Reply With Quote
Old 03-06-2017, 06:01 PM   #2
Default Re: Vanquish Incision Wraith 1/4" stainless link kit
I figured I'd post a quick update even though there were no replies. The Incision 1/4" stainless links worked out great. As I mentioned, my concern was possibly having to go with shorter rod ends to accommodate the shorter wheelbase on the AX10. But, there was plenty of overlap on the driveshafts and everything looks good, articulates well.
Old 04-01-2017, 02:19 PM   #3
Wraith and AX10 links are identical length front and rear upper and lower. The difference in wheelbase comes from the Wraiths longer skid.
SCREAMER is offline   Reply With Quote
Vanquish Incision Wraith 1/4" stainless link kit - Similar Threads
Vanquish Products Incision 4 Link Plates and shock razors. Vp Monkey Vanquish Products 13 07-03-2009 12:45 PM
