01-15-2020, 02:10 PM | #21 |
Rock Stacker Join Date: Apr 2018
| Re: Tim's take on Capra
Got any more pics of cheerwine? I haven’t drank any for years. Can’t get it easily where I live. Lol Sent from my iPhone using Tapatalk |
01-16-2020, 08:48 AM | #22 |
Rock Stacker Join Date: Oct 2009 Location: mitchill
Just hold on I got some cheerwine pleasure coming. I cant remember my sprint cars chaises maker , but with that said I do have two they all like to hang out at the local 1/5 corner. I don't know if pic portrays my idea on how I will try to build the (cms) and steering rod but here it is nun the less. |
01-16-2020, 06:34 PM | #23 |
This is a aluminum plate I marked out for the servo mount and will cut tomorrow. hopefully..
01-17-2020, 10:14 AM | #24 |
I have a start on the servo mount.
01-17-2020, 11:55 AM | #25 |
RCC Addict Join Date: Dec 2014 Location: So Cal
How thick is your servo bracket material, like .050? If so, you may find that your mount will bend under a steering load. My Bomber mount is a Z shape, (2 bends like you have, but 90 deg. each) .125 5052 and it still flexes a bit, even with the servo bracket being floor mounted and double shear'd to the chassis as well. On a side note, when you bend at your scribed bend line that the holes you have laid out will then be the material thickness closer to the bracket material above it than what you measure now before bending, in the event you didn't take that into consideration in the hole layout. I'm still trying to wrap my head around the shock links and how that will work. How do you intend to keep the caster/rear axle roll constant up front and out back? Won't the axles rotate, particularly when you get it under a serious load, requiring "traction/ladder bars"? This is great, I like outside the box builds. I spend a lot of time there myself. |
01-17-2020, 06:53 PM | #26 |
I did a little file finishing on the servo bracket and put the first bend in. and a little test fit. the two servo tabs will bend down for the servo to go thru. Last edited by Tim3; 01-17-2020 at 06:56 PM. |
01-18-2020, 12:18 PM | #27 |
I had time to work on the servo mount and getting it mounted. Remember, this Cap is v.10 version and will get another frame for the finished Cap. MAC FAB, I am winging it and there may be severe torque twist when I get V.10 out to run. just going to have to give it a run lol. I have this tendency and my friends will say this too.. why do you always take new things apart? I was going to tap some of the holes in the servo bracket but I used nuts instead. lazy me. lol. |
01-18-2020, 04:43 PM | #28 |
Done little work on the steering rod bearing pillar.
Tim's take on Capra - Similar Threads | ||||
Tim's twin hammers | Tim_ | Vaterra Twin Hammers | 0 | 05-07-2013 10:07 AM |
Tim's Defender 110 thread | darkangelv24 | 1:1 Full Size Vehicles | 3 | 12-03-2012 12:05 AM |
Tim's generosity! | Difuser | Scale Nationals | 1 | 10-17-2012 03:17 PM |
Tim's Honcho | Tim_ | Axial SCX-10 | 3 | 04-07-2010 05:26 AM |
My buddy Tim's Black Jack | mann0mann | Paint and Body | 15 | 08-05-2008 05:17 PM |
