Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Capra
Thread: Anybody with stock wheels ?
Old 01-16-2020, 01:54 AM   #1
Default Anybody with stock wheels ?
Some years ago I bought a Wraith Poison spider with plastic beadlock wheels which are quite similar to those of the Capra. Soon I replaced those wheels with better metal ones, so I delayed mounting the Capra ones thinking they are surely worse than what I'm using now. Yesterday I decided to test them because they are very light but it took half an hour to have the first finished. At the beginning the outer rings are quite far and the short M3 bolts don't reach the other side. I had to start screwing with M3x15 or M3x12 bolts, once the rings were closer I went on with stock m3x8 and finally replaced the longer ones. I really doubt the threads in the nylon ring will last long so I think these wheels are weak and difficult to mount. Is anybody using them successfully ?
Thanks
Filippo
setecastronomy is offline   Reply With Quote
Old 01-16-2020, 05:06 AM   #2
Thanks
Filippo
Use mine and like them enough. I will probably replace them eventually. It was certainly a cost cutting center for Horizon to include these cheap plastic wheels in the kit, but it’s great they still included a functioning beadlock.
The biggest issue I have with them is their lack of weight. That’s about it. Maybe someday when I grow up I’ll be able to afford a set of vanquish wheels.
ColOrBliNd is offline   Reply With Quote
Old 01-16-2020, 11:56 AM   #3
Default Re: Anybody with stock wheels ?
Most of the guys nowadays don't recommend it. But you can wrap them with lead weights to help with how light they are. Primarily the front ones though. Not the rears.
Shinobid is offline   Reply With Quote
Old 02-01-2020, 09:28 PM   #4
Same question but with hyrax tires (or I guess any proline) Is there a wheel modification or something I am missing to mount them? It's the tire in the box pictures but I cannot get the screws to even start. I'd rather buy wheels than mess up tires but am trying to use the kit wheels at least to start out.
BSmith is offline   Reply With Quote
Old 02-01-2020, 10:03 PM   #5
Curious... are you in LaGrange TX? If so I'm just up the road from you and I'd be happy to take a look at em. Usually you use two longer screws to get things sandwiched together but with you can't do that with the oem capra wheels.
high plains drifter is offline   Reply With Quote
Old 02-02-2020, 10:18 AM   #6
I appreciate the offer but I'm in LaGrange Kentucky
Old 02-02-2020, 10:36 PM   #7
Glue the bead lip to the ring, that compresses the foam, and you do not need the long screw sets.
I was doing exactly what you talk about, some beads would slip out trying to get the rims torqued down.
Super glue to the rescue, the way I cured it.
pep
JacktheRipper is offline   Reply With Quote
Old 02-11-2020, 10:11 PM   #8
Lightly squeeze them in a plastic jaw vice. They work perfect and go together quick.
Diablo169 is offline   Reply With Quote
Anybody with stock wheels ? - Similar Threads
NEW Pit Bull RC 1.9 Raceline Wheels Aluminum Wheels in black or silver - In Stock! RPP Hobby RPP Hobby 0 07-30-2019 10:50 AM
Stock RS10 Inner Wheel Diameter / XR10 Stock Wheels NullARC Redcat Crawlers 0 01-03-2014 01:39 PM
