12-08-2015, 05:56 AM | #1 |
Newbie Join Date: Dec 2015 Location: Prospect
| Yeti Motor/ESC in RR10 Bomber
I know I read it somewhere, but can't find it. Who has tried running the stock Yeti motor and ESC in their Bomber? What are your opinions. I've been wanting to upgrade the Yeti and this may be reason enough to do so. Thanks
12-08-2015, 07:02 AM | #2 |
RCC Addict Join Date: Jan 2010 Location: Vermont
| Re: Yeti Motor/ESC in RR10 Bomber
I have it in mine. Tedo's Bomber... Geared 12 / 56 on 3s and it zips. One thing I did though, is adjust my "Acceleration Forward" function on my Futaba TX. I knocked it down to 40%. It made start up relatively smooth, so it doesn't cog. I can creep rock crawl all day. I was going to upgrade, but for now, this works fine. And it's waterproof. Last edited by tedo; 12-08-2015 at 01:06 PM. |
12-08-2015, 12:59 PM | #3 |
Quarry Creeper Join Date: Nov 2006 Location: land of make believe
I'm running it in mine as well. You can see my vid in the bomber thread. Agree with tedo. Have better options on the shelf, but this being waterproof was the best option for this car and its intended purposes. |
12-08-2015, 04:38 PM | #4 |
Newbie Join Date: Nov 2015 Location: linwood
I just put my stock yeti motor and esc in my bomber the other day. It definitely helps out the speed of the truck. I am running a 13 tooth pinion with the stock spur gear. This setup does cog a little bit but still crawls pretty good for a sensor less motor. It crawls a lot better than Yeti did with the stock motor in it. Plus if you have a Castle link I'm sure you could fine tune it better to eliminate some of the cog effect.
12-08-2015, 06:20 PM | #5 |
thanks guys, i appreciate the information. what 3s batteries fit in the bomber? been looking but can't find a battery box size. Bomber is suppose to be here on Thurs.
12-28-2015, 06:26 PM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
I am about one click away from ordering a spare Yeti RTR so I can use the brushless motor in a bomber (as well as have a ton of spare parts for my Yeti). My wife got me the Axial 2 speed kit for the Yeti for Christmas, but I think the Yeti brushless motor with the 2 speed transmission in the Bomber will give me a great blend of crawl and speed, especially with some lower gearing on the spur. I don't want a 40 mph bomber, but I do want more speed using 2s than what the initial videos showed with the 35t brushed setup.
12-28-2015, 06:39 PM | #7 |
Quarry Creeper Join Date: Nov 2014 Location: WA
I just got a MMX + HH PP 540XL for my Yeti. The stock Yeti ESC/Motor + 2 speed are already in the box for the future Bomber kit! |
12-29-2015, 11:34 AM | #8 |
Quarry Creeper Join Date: Oct 2013 Location: Utah
For a sensorless type motor/esc setup with a 2speed, would you think the Yeti motor and esc or the Traxxas Velineon system would be better? I'm looking at all my options bot sensorless and sensored with a 2 speed and wouldn't mind it being waterproof either.
12-29-2015, 11:54 AM | #9 |
I ordered a Bomber and the donor Yeti from Tower last night. I also ordered a 12t and 14t spur gears to slow down the brushless bomber as necessary. The stock gearing in the yeti is 16/64, the stock gearing in the bomber is 12/64. I am not sure what the difference may be in the transfer case gearing. Axial has the yeti motor on the bomber product page as an optional part, so it must be suitable. |
12-29-2015, 12:32 PM | #10 |
Pebble Pounder Join Date: Dec 2015 Location: McKinney
One thing that would really help and is kind of fun is the 2 speed transmission. I am running it with a Pro4 3300kv sensored using a 14/64 combination, but I would think that the 3150kv system out of the Yeti even unsensored would do pretty well crawling with the low 1st speed gearing. I had an 11 tooth pinion in it and with the stock 13/38 diff gearing it was pretty good, but once I went to the hardened 13/43 in front and rear the 11 tooth was a super low 1st gear. I can say that with the 14 tooth in 2nd gear the Bomber will certainly move out, but it would be a bit too much for crawling unsensored.
01-08-2016, 04:03 PM | #11 | |
Rock Stacker Join Date: Feb 2015 Location: North Bend
| Re: Yeti Motor/ESC in RR10 Bomber Quote:
01-09-2016, 01:26 AM | #12 |
The Bomber just arrived this week, I haven't gotten a chance to run it or install anything. I do have the parts Yeti and a bunch of hobbie store baggies.
10-19-2016, 01:37 AM | #13 |
Newbie Join Date: Aug 2016 Location: Spokane
What have you decided on the Setup?
11-25-2016, 05:20 PM | #14 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
Anyone have any videos of their bomber running a yeti motor? I am going this route because I don't "crawl" much and that's what I have available.
11-25-2016, 08:44 PM | #15 |
I ran this setup briefly. I was looking for a crawler that had some top speed, the Yeti brushless setup was very fast with a 14t pinion gear, fun as heck doing 4 wheel donuts. It jumped well but did barrel rolls on hard corners. With the low gear in the two speed transmission setup it wasn't slow enough to crawl, the Yeti brushless motor cogged badly. The Traxxas 21t ($18 ) with the two speed trans, Axial low gears in the diff's, and a 11t pinion is about perfect for crawling and a good mid range top speed. I have run a couple dozen packs through it without any motor or ESC related issues. |
05-13-2017, 03:00 PM | #16 | |
Pebble Pounder Join Date: Apr 2017 Location: Fresno
I just got a good deal on a yeti esc/motor pull from a used one and I think i will use a 10 or 12t pinion on it. Thanks for posting your experience! | |
05-13-2017, 05:17 PM | #17 | |
If you are installing it in a Bomber without the 2 speed kit and standard gears I think it'll be faster than the chassis can handle even with the 10t. | |
05-13-2017, 08:14 PM | #18 | |
Rock Stacker Join Date: Jul 2013 Location: North West CT
05-13-2017, 09:23 PM | #19 |
I am running the Traxxas 550 21t motor with the stock Axial AE-5 ESC and radio. Motor gearing is 11/64 with the Robinson Racing 64t Gen3 slipper. I am running the Axial aluminum motor mount. Gearing is the Axial 2 speed kit with the optional higher speed high gear. Diffs are running Axial 43/13 gears with aftermarket spools. I have upgraded the steering servo to the 7950 with a Castle BEC, my stock steering servo runs the 2 speed. All runs have been 3s with a 5100 mAh soft pack. No problems with this setup in dozens of packs. I never ran the stock Axial 35t motor. Here is the Traxxas motor on Amazon: https://www.amazon.com/Titan-21-Turn.../dp/B000BONYBC |
05-13-2017, 09:32 PM | #20 | |
Thanks. That is good info. I'll look at chaining the main gear I don't really want to change both axles out :: I appreciate the feedback | |
Yeti Motor/ESC in RR10 Bomber - Similar Threads | ||||
Rr10 bomber available from tower | jaykim5708 | Axial RR10 Bomber | 12 | 05-05-2016 07:28 PM |
No Axial RR10 Bomber section? | ROLANDROCKSHOP | Comments, Suggestions, and Help | 8 | 12-26-2015 04:06 PM |
