12-11-2015, 05:48 PM | #21 |
| Re: Duuuuuuuudes Bomber I'm hoping to get new links made this weekend. |
12-12-2015, 12:40 PM | #22 |
Decided to go ahead and replace all of the electronics. The stock 35t just wasn't doing it for me on a rig like this. Traxxas ET3s esc Tacon 2200kv 4 pole (non-sensored) Castle bec Hitec HS7954SH I was a little concerned about speed with the UD gears all around, but it turned out to be a non-issue. Lots of rip, speed decent enough to catch some air, and decent enough crawlability. I may go with a HH Puller Pro in a similar kv to gain some low end control. Torque twist is greatly reduced with the gears and sway bar (using the lightest spring). Put the hammer down from a dead stop on asphalt and it'll pick one tire up an inch or so before it goes into full wheely mode. |
12-12-2015, 02:11 PM | #23 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Have you hacked your ET3S into being a full MMP?
12-12-2015, 02:25 PM | #24 |
No, I haven't had the need. Unless there is a hack to make the wires longer...
12-16-2015, 05:55 PM | #25 |
I've been thinking long and hard about what DCW might bring to the Bomber party. With so many vendors it's hard to find a niche that hasn't been run through already, but I have a few things in mind that I haven't seen yet. There were also a couple of items I had on my Wraith that never saw production and that I've kept more or less secret, and I'll be revisiting those as well. I'll be shutting down through the holidays so I can dedicate serious time to developing some stuff. It's been a while since I've had the chance to do that, so I'm excited. In the mean time, progress. Universals - in New upper links - fabbed and in Dual Stage shock pistons - in COG - found Geometry - inspected I'm really a big fan of the dual stage pistons. I set them up last night with 40wt in the rear and 30wt in the front. Tonight I'll dump all that out and go 30/25. Overall it was quite a bit more stable at speed, but just a bit harsh. |
12-17-2015, 01:21 AM | #26 |
RCC Addict Join Date: Aug 2007 Location: Seattle
Slow compression on front and back?
12-17-2015, 07:50 AM | #27 | |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
| Re: Duuuuuuuudes Bomber Quote:
12-17-2015, 07:52 AM | #28 |
| Re: Duuuuuuuudes Bomber |
12-17-2015, 11:51 AM | #29 |
The light weight does make tuning problematic, but it's still an improvement over stock. I first ran dual stage a few years ago in my sc truck...made a huge difference, even before I got the fluid right. |
12-17-2015, 01:36 PM | #30 | |
12-17-2015, 01:58 PM | #31 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
12-17-2015, 02:00 PM | #32 |
Sad to say that rotors wont be available for a while yet. |
Duuuuuuuudes Bomber - Similar Threads | ||||
Tedo's Bomber | tedo | Axial RR10 Bomber | 3 | 02-08-2016 07:47 AM |
About to get an Axial bomber | thatchvol | Axial RR10 Bomber | 12 | 12-07-2015 08:08 AM |
Duuuuuuuudes Yeti | Duuuuuuuude | Axial Yeti | 96 | 10-17-2014 02:07 PM |
Backwoods Bomber | Duuuuuuuude | 1.9 Scale Rigs | 153 | 06-11-2012 08:41 AM |
