12-12-2015, 07:38 PM | #1 |
Rock Stacker Join Date: Jul 2015 Location: York
| Axial rr10 bomber question
Does the mip driveshaft from the yeti fit on the bomber?
12-12-2015, 07:54 PM | #2 |
| Re: Axial rr10 bomber question
That's what I'm running on my centered rear and it's perfect. Offset rear might be a different story since it will be a shorter distance to the output. None of the splines show on mine at full droop.
12-12-2015, 07:58 PM | #3 |
Ok hopefully someone will chim in that did to clarify if it def works. Don't want to waste my money if it doesn't.
12-12-2015, 08:09 PM | #4 |
Rock Crawler Join Date: Aug 2009 Location: San Antonio
| Re: Axial rr10 bomber question |
12-12-2015, 08:47 PM | #5 |
What trailing arms you running an do you like them?
12-12-2015, 08:53 PM | #6 |
SSD, so far so good.
12-12-2015, 08:59 PM | #7 |
Did you run it without them when you first got it?
12-12-2015, 09:01 PM | #8 |
Yes....I made some changes when I switched to brushless.
12-14-2015, 12:32 AM | #9 |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
To puggyback on this topic, what are people using for the front? Sent from my SM-G900P using Tapatalk |
12-14-2015, 07:59 AM | #10 |
RCC Addict Join Date: Aug 2013 Location: Missoula
12-16-2015, 05:01 PM | #11 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
just wait for it... the yeti rear drops right in. mip does not make a setup that drops into the front. |
12-16-2015, 09:02 PM | #12 |
12-17-2015, 08:41 PM | #13 |
Newbie Join Date: Nov 2015 Location: Upland
12-17-2015, 08:42 PM | #14 |
Nope, plug and play. Sent from my iPhone using Tapatalk |
12-18-2015, 03:37 PM | #15 |
Awesome! Thanks!
Axial rr10 bomber question - Similar Threads | ||||
axial RR10 bomber new U4 class? | Cork | U4RC | 2 | 01-15-2016 11:22 AM |
No Axial RR10 Bomber section? | ROLANDROCKSHOP | Comments, Suggestions, and Help | 8 | 12-26-2015 04:06 PM |
New Axial RR10 Bomber available for pre-order! | RPP Hobby | RPP Hobby | 0 | 11-09-2015 05:48 PM |
