12-18-2015, 06:37 PM | #1 |
Pebble Pounder Join Date: Dec 2015 Location: McKinney
| Need recommendation on HD diff gears please
I just recieved my Bomber today and am waiting on a few things to come in. I am going to be running a MMP with a Tekin Pro4 3300kv on 3 cells, probably start off with a 12 tooth pinion although I have a 13t and 14t that I can try as well. My question is what HD diff gear and pinion would be recommended to run? I see where some people will run one ratio in the front and a different one in the rear, I have seen it referred to as over/under. What are the benefits of running the two different ratios? Obviously not good for solid ground, but that is not where I intend to run it anyway. I just need an idea on what to pick up. I think after that I will do MIP driveshafts, front cv's, suspension arms and maybe different spools if needed. Pretty easy to spend a lot of money on these thing very rapidly isn't it? Thanks for the input. |
12-18-2015, 07:53 PM | #2 |
| Re: Need recommendation on HD diff gears please
If you want to reduce torque twist, turn sharper, and climb better then 43/13 rear and 38/13 front.
12-18-2015, 08:00 PM | #3 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
^^^ What he said |
12-18-2015, 08:15 PM | #4 |
Rgr, thanks gentlemen
Need recommendation on HD diff gears please - Similar Threads | ||||
diff gears | airride | Axial SCX-10 | 1 | 02-24-2015 08:22 PM |
Diff gears | OKJeepin | Losi Mini-Rock Crawler | 2 | 04-23-2012 06:01 PM |
Diff Gears | White Stripe | Traxxas Crawlers | 0 | 11-20-2010 02:21 PM |
4.1 diff gears where from? | 1tuff40 | Tamiya Txt-1 and Juggernaut | 4 | 08-01-2008 01:27 PM |
