12-19-2015, 08:22 PM | #1 |
Rock Stacker Join Date: Jun 2014 Location: Pasadena,Texas
| ratrod63's Bomber
I bought a new Bomber from Tower a couple weeks ago. As soon as I pulled it out of the box I began to take it apart. Then I tore it down to start installing the Axial 2 speed conversion. |
12-19-2015, 08:35 PM | #2 |
| Re: ratrod63's Bomber I used the Axial 2 speed conversion for the Yeti. I used the stock steering servo for the shifting servo. It fit in the supplied bracket perfectly. I installed a set of built Wraith axles. Vanquish Yeti rear upper links Carter Fab trailing arms ( I bought Vanquish arms at first but decided to use the Carter Fab instead) Dlux Yeti rear sway bar kit I also threw in my Futaba receiver , Tekin RS gen 2 and Tekin 17.5 brushless I put on a set of Vanquish Method 105s with Dueces Wild foams and Voodoo U4 SIlver tires. |
12-20-2015, 11:52 AM | #3 |
I took the Bomber out on its maiden voyage and quickly learned that the Tekin 17.5 is just not enough motor. I made a trade with a buddy and got a Holmes Hobbies Trailmaster 3300bv motor. Got the new motor installed. While I had the body off,I re-programmed the esc for drag brake. I forgot to do it when I first put it together. It was set to delay reverse and it sucked out on the rocks. While I had the skid dropped I figured I would snap a pic of the shift servo installation. The stock steering servo works great for a shifter! I also kept having problems with the spare tire hanging up on rocks. So off it goes! Last edited by ratrod63; 12-20-2015 at 11:57 AM. |
12-20-2015, 01:16 PM | #4 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
very nice, I like it. im on the same road with mine, how do you like the H.H. motor? hows the wheel speed, how dose it do on the rocks.. with the 2 speed..
12-20-2015, 05:43 PM | #5 |
| Re: ratrod63's Bomber The H. H. motor works great. Very smooth and fast when you want it to be. The 2 speed works great. It is probably not necessary to have the two speed with the brushless setup. I just wanted to try it out. The wheel speed is great in low for crawling and in hi gear it hauls butt!
12-20-2015, 05:47 PM | #6 |
Here are some pics from today's run. |
12-20-2015, 07:37 PM | #7 |
RCC Addict Join Date: Jun 2006 Location: Maryland
Clean looking build and nice pics! How do you like the 2 speed? Do you shift a lot or do you find it does about everything you want in one gear?
12-20-2015, 07:51 PM | #8 | |
| Re: ratrod63's Bomber Quote:
I also have a built Wraith with a Tekin Pro 4 3300. I find that sometimes while I am crawling I get too excited and blip the throttle too much. The Wraith goes flying thru the air like a jackrabbit! With the 2 speed in the Bomber , I crawl on rocks in low gear. That way if I get to throttle happy it is no where near the wheel speed of high gear. It just makes it easier to drive. | |
12-20-2015, 09:26 PM | #9 |
looking good... I did pull the trigger on the H.H 3500kv motor. thanks for the input.. cant wait to get it done see how its going to do..
ratrod63's Bomber - Similar Threads | ||||
Bomber Batteries | JesterSpec | Axial RR10 Bomber | 129 | 05-18-2020 11:03 AM |
Tedo's Bomber | tedo | Axial RR10 Bomber | 3 | 02-08-2016 07:47 AM |
Bomber vs. Wraith? | fyrstormer | Axial RR10 Bomber | 25 | 01-20-2016 04:00 AM |
EmeryworX bomber | tuner | Axial RR10 Bomber | 5 | 12-13-2015 06:31 PM |
About to get an Axial bomber | thatchvol | Axial RR10 Bomber | 12 | 12-07-2015 08:08 AM |
