01-12-2016, 04:30 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
| rr10 links
What are my options for stainless or tie steering links and does it change if i go with vanquish or ssd hubs?
01-12-2016, 04:41 PM | #2 |
Newbie Join Date: Oct 2015 Location: Milky Way
| Re: rr10 links
I believe people are using upgraded front links that are listed for the wraith. I don't know about the knuckles.
01-12-2016, 04:48 PM | #3 | |
| Re: rr10 links Quote:
Any Wraith link for the front will work from VP, SSD, 4x4, DLux etc. with no effects. Maybe a turn or two on a tie rod end but that's not unusual | |
01-12-2016, 05:07 PM | #4 |
Quarry Creeper Join Date: Oct 2010 Location: Pa
| Re: rr10 links
Save money, build your own front links & rear upper links. If you're not interested in building your own there is a quite a few high dollar items which aren't any more beneficial than some of the ones on ebay, or home made ones on here. Just do a little research this place has a lot of info so I can understand the question, but in the long run if you spend the money correctly you'll end up in a better spot. Cheers! Last edited by F1GHTF1R3W1THF1Re.; 01-12-2016 at 05:28 PM. Reason: clarification. |
01-12-2016, 07:15 PM | #5 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: rr10 links
I think brake line, tube bender and 8-32 die would do the trick. I'm making mine out of solid stainless 3/16 & 1/4 rod. But I went VP 1st time because i didn't know better. J.A.W - just another wraith & a Bomber! |
01-13-2016, 08:13 AM | #6 |
| Re: rr10 links
Thanks found a set through rpp everybody else seemed to be out of stock new bomber should be here by the end of the week can't wait !!!!!!!! |
01-13-2016, 08:49 AM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: rr10 links
I would highly recommend using a solid threaded rod with 4mm revo/jato style ends. The drilled/pinned/3mm style is much much weaker. VP uses this style, as do others I'm sure. I made my own from 5/32" music wire, it was miserable to thread and I wound not advise anyone to try and repeat it |
01-13-2016, 10:53 AM | #8 |
| Re: rr10 links
I have a full stock of Bomber links waiting to ship to their new owners. Trailing arms are still 1 to 1.5 weeks out I am told. https://dluxfab.ecwid.com/#!/Bomber-...nks/p/56237898 |
01-13-2016, 10:59 AM | #9 |
| Re: rr10 links
Thanks trailing arms are next on the list
rr10 links - Similar Threads | ||||
RR10 2-speed | Jus | Axial RR10 Bomber | 83 | 02-22-2020 11:15 AM |
Axial rr10 | ptaryan654 | Axial RR10 Bomber | 1319 | 06-10-2018 08:06 AM |
Trying out parts from the RR10 | Chiphead | Axial Yeti | 7 | 11-24-2015 11:01 AM |
Axial RR10?? | skybolt | Chit Chat | 12 | 11-09-2015 09:05 AM |
