01-19-2016, 10:32 AM | #1 |
Rock Stacker Join Date: Jan 2016 Location: North East Ohio, In the Lake
| Bomber Rear Lower Trailing Arms
If I understand correctly from reading on here. Yeti Rear lower links are a direct fit for a bomber. Are the Yeti upper rear links the same also? Anyone have any other advice for the yeti replacement lowers, besides the "Vanquish Products Aluminum Trailing Arms for Axial Yeti"? Are the Wraith front upper and lowers the same as the Bomber? I see that the Wraith drag link and steering bar is the same as the Bomber. Any other Axial parts a direct fit, or close to it? |
01-19-2016, 10:35 AM | #2 |
| Re: Bomber Rear Lower Trailing Arms
Yes everything is Wraith front and Yeti rear. Trailing arms choices are Vanquish, DLux, hot racing, blue monkey, Carter fab, Werty made, etc.
01-19-2016, 10:40 AM | #3 |
Rock Stacker Join Date: Dec 2015 Location: Cincy
Yeti rear uppers and lowers Wraith front upper and lowers There are some 6pc Bomber kits out now...4 front links and 2 upper rears. Wraith steering links... I have Vanquish lowers and have no complaints. They are burly and very well made. I have American Machine Works front and rear upper links...Also well made (in Ohio!) and very reasonably priced. 38 bucks for the links and revo ends. I have Vanquish Ti steering links but would have have purchased the American Mach Works kit had I seen it first...the Ti does hold up well to the beating it takes from rocks however. The Vanquish stuff I got from my LHS...the American Mach Works links were purchased on Ebay. Dlux has some very nice looking delrin links that I will try next. Super shafty has lnks as well. |
01-19-2016, 12:21 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
These are also an option, haven't heard of them or seen anyone running them though. I kinda like how they don't hang down like all the other trailing arms so you gain some ground clearance. Not nearly as nice as Dlux or Vanquish but will likely get the job done too. Axial RR10 Bomber Axial Yeti Trailing Arms Pair | eBay |
01-19-2016, 02:35 PM | #5 |
Pebble Pounder Join Date: Mar 2013 Location: Lehi
I've also seen the DLux Wraith trailing arms used that shorten the wheelbase (Screamer) I'll be going that route just as soon as I get the rig and can get my hands on a pair. On those lines, would the Twin Hammers rear trailing arms work?
01-19-2016, 02:40 PM | #6 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Trailing arms hang down so the shock is mounted below the centerline. Mounting the shock even with the end will make for a floppy link and lots of weird side loading of the ends.
01-19-2016, 03:45 PM | #7 | |
| Re: Bomber Rear Lower Trailing Arms Quote:
Axial Racing Silicone Shock Bushing 7.5x8mm (6pcs) # AXA1356 If it actually works, bent lower trailing arms can be ran without any ill effects besides choosing the right length shock | |
01-19-2016, 07:15 PM | #8 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Re: Bomber Rear Lower Trailing Arms |
01-19-2016, 08:35 PM | #9 | |
If the weight of the rig (the shock) is mounted level with the ends, the link will twist around and not sit flat. If the shock is below the ends, the weight keeps the link flat and the ends loaded correctly. As stated above, in 1:1 world people get around this with pucks on the heims or Johnny joints that pivot more than rotate. Limiting the misalignment of the joint limits "flex." You are building in binding to combat physics. I don't see any good way to accomplish the same in RC land. Some fat o rings on the revo ends would probably be best, usually only at the skid end, unless you need more twist reduction. Plastic ball ends don't last an hour, rubber wouldn't make it 5 minutes. Nitro fuel line splits and falls apart too easily. Or you can mount the shock below the center line and not worry about it. | |
01-19-2016, 09:31 PM | #10 | |
01-19-2016, 09:40 PM | #11 |
| Re: Bomber Rear Lower Trailing Arms No, sorry. The arms that were linked from ebay a few posts back. Raising the mount does give slightly better clearance, while creating new issues.
02-04-2016, 10:20 PM | #12 |
Quarry Creeper Join Date: Nov 2008 Location: The land of bagged milk
speaking of trailing arms...has anyone tried Werty made?
09-01-2019, 11:56 PM | #13 | |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Do you know what Yeti trailing arms mounts shock below rod ends? | |
09-04-2019, 05:11 AM | #14 |
09-04-2019, 07:00 AM | #15 |
RCC Addict Join Date: Dec 2014 Location: So Cal
There is this company, https://www.metalconceptsrc.com/, king of TT parts.
02-21-2021, 08:56 AM | #16 |
Newbie Join Date: Jul 2017 Location: Mentone
Who makes steel ones ???
02-22-2021, 08:29 AM | #17 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
02-23-2021, 06:58 PM | #18 |
Bomber Rear Lower Trailing Arms - Similar Threads | ||||
SCX10 Bomber - Trailing Arms? | Ahod39 | Axial SCX-10 | 23 | 01-18-2016 01:51 PM |
Yeti Rear Axle W/ center diff & lower trailing arms | XJsport95 | Axial Yeti | 15 | 01-21-2015 09:33 PM |
BMRC Lower Trailing Arms | Rckhrse | Axial Wraith | 0 | 08-22-2013 10:13 PM |
