04-05-2016, 07:30 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: Farmington
| How well does the bomber crawl?
I am looking at getting back in to the sport does the bomber crawl well? Is there lots of torque twist, cog? I appreciate any info you all are willing to share.
04-05-2016, 07:54 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
| Re: How well does the bomber crawl?
I think the Bomber crawls well, but I am just back into the hobby as well. I haven't owned a Wraith or any other crawlers since the old AX-10 my buddy loaned me in 2010. The AX-10 was a more purpose built crawler with sensored brushless power, a 4:1 reduction box, and 4 wheel steering. That rig crawled everything, but was so slow it was boring after a short time. My Bomber is far more fun all around while still seeming competent as a crawler. It does roll off the rocks once in a while (usually sideways) but if you are pushing it's limits that will happen with any rig. Others may disagree, but I get plenty of fun out of it. Mine is modified with a Traxxas 21T brushed motor, 2 speed gearbox, 43/13 gearing, beef tubes, good steering servo, titanium links, UCFAB yeti length trailing arms. My issues crawling are the stock tires/foams are too soft and it does drag the belly once in a while. I have new tires/wheels/foams on order, and was reading the thread about shortening the wheelbase to keep the belly from dragging. I really do enjoy bashing it and still being able to hit the low gear to do technical crawls (it does crawl fine in high gear with the current setup). |
04-05-2016, 08:08 PM | #3 |
Thanks that info helps a lot. It will be different going from a Moa which I was big into back when berg and xr10 scene was big. seems that the sport has changed a lot.
04-09-2016, 07:14 AM | #4 |
Quarry Creeper Join Date: Jan 2007 Location: Fallon, NV
There is gobs of torque twist but it is manageable with a sway bar but other than that it's decent at it Sent from my SM-N910V using Tapatalk |
04-09-2016, 10:44 AM | #5 |
I experimented with Yeti brushless power in my Bomber and yes the torque twist was very problematic. Going to UD gears helped significantly. I ordered the Axial sway bar kit to tame it more, but it is really too stiff and prevents the rear from flexing enough. The solution was going back to brushed power, that 3150kv Yeti motor with a 12t pinion was just too much speed for this rig. With the speed it barrel rolled on hard corners unless you could drift the rear end. With the Traxxas Titan 21T motor, UD gearing, and the sway bar removed it does great. Occasionally the front tire does come up on a climb, but it crawls slow enough with the 2 speed that I can tap reverse and put it back down to try a different line. I may try thinning the Axial sway bar to soften it, but at this point I am happy without it.
04-09-2016, 09:48 PM | #6 |
Rock Stacker Join Date: Oct 2014 Location: Northern Los Angeles
I found the stock rig to be a very competent crawler.
04-11-2016, 08:58 PM | #7 |
Newbie Join Date: Apr 2014 Location: IE
Is like to ask what everyone's thoughts are on the bomber vs wraith? Have the ability to buy either one for a rock racer that can have some fun crawling as well... Am I wrong to assume goin with the bomber would be a better choice based on technology alone? Seems like a beefed up wraith... Thanks
04-11-2016, 10:42 PM | #8 |
Wraith should be a better crawler due to the shorter rear trailing arms, allowing it to drag the belly less on the rocks than the longer wheelbase Bomber. Others seem to speak highly of the Wraith transmission due to it being lighter weight and lower center of gravity, but I have never used one and like the 2 speed Yeti trans in my Bomber. Some are doing the Wraith length trailing arms and even the Wraith trans on the Bomber. I may experiment with the shorter trailing arms at some point, but I am pleased with Bomber performance on my current setup.
04-11-2016, 10:58 PM | #9 |
Good to know.. I'm curious what the deal with the two speed trans is?
04-11-2016, 11:31 PM | #10 |
The 2 speed gearbox uses a servo and the third channel on your radio to shift gears to a standard high gear and a 2:1 reduction low gear for crawling. If you want to crawl and go fast with the same rig it is helpful. I purchased the Axial, but the SSD is $30 cheaper. SSD 2 Speed Transmission Conversion Kit for Yeti |
04-12-2016, 06:01 AM | #11 |
Alright cool I'll check it out. Thanks man
04-12-2016, 07:01 AM | #12 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
Long wheelbase gives it some problems, the belly tends to hang up. Other than that it will crawl just as the Wraith. On very steep inclines the long wheelbase is a advantage. Can't tell any major differences between these two.
04-12-2016, 11:56 AM | #13 |
Newbie Join Date: Apr 2016 Location: Conway
| Re: How well does the bomber crawl? I went with the twin hammers length rear trailing arms, and its made it a much better crawler. It still wants to twist some, but way better then it was stock.
04-12-2016, 01:09 PM | #14 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
With the Twin Hammers trailing arms, what other modifications did you have to make? Different upper links in the back as well? What about the drive line?
04-12-2016, 07:11 PM | #15 |
Looking into this IFS setup people are talking about on here. Looks awesome, seems to work ok from the videos I've watched but it's more stuff to break and/or go wrong. Any thoughts?
04-12-2016, 09:23 PM | #16 | |
| Re: How well does the bomber crawl? Quote:
I used wraith length uppers and then switched out to the short tubes and spline for the driveshaft from the extra parts tree. Rather easy actually. I bought the cheap plastic lower arms to made sure I liked them, and will probably order better ones now. | |
How well does the bomber crawl? - Similar Threads | ||||
tryina find people to crawl with and or places to crawl | wraithscailer | General Crawlers | 3 | 12-02-2012 10:27 PM |
