04-20-2016, 05:43 PM | #1 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| DLux sway bar install?
Received DLux sway bar today. Few questions: 1) Should it come with screw and nut to attach the arm to the link? I already contacted DLux. Waiting to hear back. 2) I purchased soft and medium bars for front and back installs (I like options). Is the shorter bar for the back and longer for the front? 3) I know the hole in the arm is drilled for soft bar diameter but should the hole be drilled all the way through the arm? Seems like the hole on the back side of arm is partially drilled and therefore the bar doesn't go all the way through. 4) What are the white plastic bushings for? Thanks. |
04-20-2016, 06:55 PM | #2 |
Newbie Join Date: Jul 2015 Location: Lenoir City, TN
| Re: DLux sway bar install?
1) yes it should come with hardware to connect the links. 2) Did you get the rear bumper mount version or the other?...i only ordered the .93 bar so I didn't realize they are different lengths. 3) I just drilled on through, won't matter either way bc it barely sticks out when installed. Can hardly tell. 4) The white bushings act like a spacer. Slide the bar through the holes then slide the white bushings on next and then the arms. I also used some threadlock on the Grub screw that holds the bar into place. Last edited by Steven4x4; 04-20-2016 at 06:57 PM. |
04-20-2016, 07:13 PM | #3 |
Thanks! I got both the front bumper and rear bumper mount in case I want to switch it up. Not sure if short or long bar goes on rear or front and vice versa. |
04-21-2016, 02:28 AM | #4 |
I would go with longer bar in the rear. Did a rough measure of my. 93 bar it's 4 1/4" and I have the rear bumper mount sway bar.
04-21-2016, 05:15 AM | #5 |
Perfect. You have been a great help!
04-21-2016, 06:31 AM | #6 | |
| Re: DLux sway bar install? Quote:
2) "Is the shorter bar for the back and longer for the front?" Yes 3) They should be drilled all the way through. Make sure the set screw isnt what is preventing it from going all the way through. 4) They go between the arms and the plastic chassis to make sure the arms are at the correct width. | |
04-21-2016, 07:01 AM | #7 |
1) Sent you a Pm on hardware 3) Took set screw out and they are not drilled all the way through. I will drill myself. |
04-21-2016, 06:29 PM | #8 |
Okay guys. I must be a complete moron. I have clearance issues between chassis and arm as shown in these photos. What the heck am I doing wrong? |
04-21-2016, 08:01 PM | #9 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Sure it mounts from forward location with links back to axle, same as Yeti
04-21-2016, 10:11 PM | #10 |
Pebble Pounder Join Date: Sep 2010 Location: Buena Park
What if you switch the link to the other side. Sent from my iPhone using Tapatalk |
04-21-2016, 11:18 PM | #11 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Your links that mount to end of sway to trailing arm is on wrong side. See the 3 counter sunk holes, its meant for a flat head screw. Dlux has pictures on his site.
04-21-2016, 11:37 PM | #12 |
| Re: DLux sway bar install? |
04-21-2016, 11:57 PM | #13 |
04-22-2016, 12:50 AM | #14 | |
You are correct on them having a slight step on one side, that may help in this case. I think this just needs a slightly longer spacer. | |
04-22-2016, 05:09 AM | #15 |
Here is a photo of it installed on another rig and it looks like there is more clearance? Wth.... |
04-22-2016, 09:42 AM | #16 |
Is it hitting the forward sway bar mount? Just remove it if it is. That's the only thing that it looks to be hitting. If you notice the picture with more clearance doesn't have it. Sent from my iPhone using Tapatalk |
04-22-2016, 09:50 AM | #17 |
No, it's the rear chassis where the screw is on the corner that is rubbing the sway bar arm.
04-22-2016, 10:08 AM | #18 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
04-22-2016, 10:30 AM | #19 |
If I space them out more then I will run out of bar and/or have slop since they are currently flush with the spacers.
04-22-2016, 10:37 AM | #20 |
So far on this purchase...I did not get the hardware I should have (wants $5 to ship 2 screws and 2 nuts to me), had to drill the holes through since they weren't completely drilled, and I have chassis rub on the rear mounting location (incorrect spacer size or bar length potentially?). Sold my VP bar because of the rave reviews on this and the ability for multiple mounting options. So far, not too thrilled with this purchase.
DLux sway bar install? - Similar Threads | ||||
Ok... What am I missing - Wraith Sway Bar Install | byrnieman | Axial Wraith | 5 | 09-02-2015 07:29 PM |
DLUX sway bar | pro mod steve | Axial Yeti XL | 14 | 04-26-2015 11:45 PM |
HELP - Need ideas for sway bar install | WesTX | General Crawlers | 5 | 12-20-2014 05:52 PM |
Install or not? Front Sway Bar | Blinkfan5150 | Vaterra Twin Hammers | 3 | 03-27-2013 03:27 PM |
