05-21-2016, 02:42 PM | #1 |
Rock Stacker Join Date: May 2016 Location: USA
| Mopar2Ya's Bombs Away
I got an Ascender a few months ago, & got the crawler bug. The Ascender was for a young one to have something slow, so now I'm working on a Bomber. I thought about buying a roller/chop shop parts, but decided on the RTR, after looking it over, I think I should have built it from parts. I did need the motor for my Ascender. Oh well I'll have kool paper weights now. Parts list: RR10 Bomber RTR HH Trailmaster BLE Pro wp HH Crawlmaster Pro 16T HH Trailmaster HV500 CC BEC R4EH-G (gyro disabled) DMG axle skids Vanquish sway, servo mount & clamps Axial motor mount & slipper plate Freqskinz RC4WD Raceline 2.2 wrapped in RC4WD Mudbasher 2.2 Still waiting for: BlueMonkey complete link kit Pro-Line Pro-Spec shocks I've been looking at metal axle housings, but am unsure if I want them w/the reviews I've read that they get hung up much easier than plastic. Thoughts? Last edited by Mopar2Ya; 05-21-2016 at 02:47 PM. |
05-21-2016, 05:38 PM | #2 |
| Re: Mopar2Ya's Bombs Away
Nice looking build. I have 2 rigs with aluminum axles and 4 running plastic with some sort of beef tube. I honestly can't tell a difference in crawling performance between the two. All my trucks perform well.
05-21-2016, 08:11 PM | #3 |
| Re: Mopar2Ya's Bombs Away TY. I want to get the SSD housing, w/the centered rear. Does anyone make a pumkin skid for the SSD's ( like the DMG's for the stock housings)?
05-21-2016, 08:45 PM | #4 |
SSD does in fact. It's a real nice delrin slider. I ran one of them in another build and they're great. SSD makes a really nice axle. Here's a link for the skid. http://www.ssd-rc.com/skid-for-diamond-axle.html Also be aware, with a centered rear there may or may not be clearance issues with the rear driveshaft hitting the transmission. The stock driveshaft will most definitely make contact. There are things you can do to help but it's not ideal to move the rear driveshaft over so far. Just wanted you to have an idea of what's involved. I'll say this, SSD decided to make a new truss just so their front axle could be ran in the rear as an offset pumpkin. They wouldn't have done this for no good reason. Some have even switched to centered rears then switched back when they got tired of dealing with the clearance issues. Last edited by SCREAMER; 05-21-2016 at 08:55 PM. |
05-21-2016, 09:04 PM | #5 | |
| Re: Mopar2Ya's Bombs Away Quote:
05-21-2016, 09:17 PM | #6 |
Here's the best pic I can find to explain the issue. This is an SSD driveshaft and an offset rear axle. This is from the back of the trucks underside looking up and forward. With the suspension uncompressed you can see how close the the driveshaft already is to the trans. If you then move the differential to the right, the driveshaft also angles to the right and that's were you start to have problems. Some of the "fixes" I've seen used are running a horrible pinion angle by rotating the axle forward to move the driveshaft down and try to gain clearance, running a MIP driveshaft because they are super thin and have more clearance, and removing material from the trans cover itself or a combination of these three.
05-21-2016, 09:24 PM | #7 |
| Re: Mopar2Ya's Bombs Away I haven't seen anything that covers the complete underside of the SSD like the DMG skid. They claim it's a ground clearance issue and honestly, the axle is stout and would have a long service life still. I'm with you though and prefer better protection. That's why I run plastic axles with DMG skids or my Curries with titanium skids.
05-21-2016, 09:59 PM | #8 | |
05-21-2016, 10:07 PM | #9 | |
The problem I, and others, see with the F9 is that there is no skid option to smooth out the transition from the pinion to the bottom of the diff. This would get hung up a lot more than the Currie Rock Jock or SSD with its delrin skid. Other than that, the F9 is another VP home run. I'd even say it'd be fine for a front axle since your not really too worried about hindering your rearward progress as much as driving forward. | |
05-25-2016, 01:46 PM | #10 |
I got my first run, & had no breakage. I did have to shave the webbing on the front of the cage as it hit my servo. The steering isn't good yet, I still have the plastic links on, until the BM links get here soon. How much will my steering angle improve if I upgrade to CDV or uni's up front? I may tweak w/my shocks more eventually, up front I'm running dark blue springs w/32.5wt oil, in the back I have yellow springs & 20wt oil. I'd like a little more flex. |
05-25-2016, 04:25 PM | #11 |
Universals are a huge gain in steering angle and strength. Those should most definitely be your next mod. Here's stock next to unis.
05-25-2016, 05:01 PM | #12 |
Newbie Join Date: Apr 2016 Location: Ballsackistan
screamer I think you may yet persuade me to FINALLY upgrade my bomber. I have to admit going back and forth to make a turn on obstacles is more than little annoying so I'll definitely be purchasing some universals. I just need some suggestions on servos and steering links.
05-25-2016, 05:13 PM | #13 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Your flex is going to be limited with the vp sway bar.
05-25-2016, 08:44 PM | #14 | ||
Yeah, I figured the sway was some of the issue. I may grind it a bit. | ||
05-25-2016, 08:52 PM | #15 |
DLux's new universals are the strongest choice IMHO. If you can't spend that much, regular Axial unis are an excellent choice. VP VVDs are also a great choice but limit steering to 48 degrees which is still much more than the stock dog bones. SSD makes HD CVDs now too, that's one I haven't tried but SSD is a solid company. Those are the ones I would feel confident suggesting. Stay away from cheap, you'll just have to replace them and spend more. Dlux Fab Wraith VVD V1-HD - Vanquish Products HD CVD Axles for Wraith / RR10 Last edited by SCREAMER; 05-25-2016 at 08:58 PM. |
05-26-2016, 03:21 PM | #16 |
Yeah I'm not cheeping out on this piece. I'm not as hardcore as some of you guys but I'm definitely not trying to buy the same part over and over, not to mention i still have to look like i know what I'm doing. I may grab the ones from SSD, as I have been thinking about switching too their axles too.
05-28-2016, 06:01 PM | #17 |
| Re: Mopar2Ya's Bombs Away Last edited by Mopar2Ya; 05-28-2016 at 06:07 PM. |
05-31-2016, 02:06 PM | #18 |
Newbie Join Date: Feb 2015 Location: The middle
I love the mud basher xls favorite tire so far
05-31-2016, 09:52 PM | #19 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
Your truck looks fun! Love the combo of the paint and tires. Sent from my SM-N910V using Tapatalk |
05-31-2016, 10:42 PM | #20 |
| Re: Mopar2Ya's Bombs Away |
Mopar2Ya's Bombs Away - Similar Threads | ||||
Mopar2Ya's Ascender | Mopar2Ya | Vaterra Ascender | 8 | 06-23-2016 05:17 PM |
crawling on volcano's bombs | Cirederf | Videos! | 0 | 09-24-2011 11:29 AM |
Augusta scaler + fire video (NWS..couple f-bombs) | Scattman | Videos! | 4 | 04-22-2008 10:58 AM |
Twin 500 lbs bombs | RodyRazorBackc5 | Chit Chat | 4 | 06-15-2006 07:11 AM |
