07-06-2018, 08:48 PM | #1 |
Rock Stacker Join Date: Jun 2018 Location: Simpsonville
| How much slack is allowed between the c-hub and knuckle?
I've been checking my Bomber for the weekend run and I found that the front wheels have a lot of slack/play... everything seems tightened, but the upper and lower joints between the c-hubs and knuckles are very loose. I don't remember seeing this way from the beginning... Vanquish F9 AR60 axles with Vanquish c-hubs and knuckles (the regular ones, not the scale ones). Has anybody experienced this? If it is bad, how to fix it? |
07-06-2018, 09:13 PM | #2 |
| Re: How much slack is allowed between the c-hub and knuckle?
Check the hat bushings for wear Hang up and Drive |
07-06-2018, 09:25 PM | #3 |
Put new ones of these in - Vanquish Products Knuckle Bushings: https://www.rpphobby.com/product_p/vps07510.htm If they don't fit perfectly, you can either file the bases thinner (if they are too tight) or add washers between them and the knuckle (if too loose). Last edited by durok; 07-06-2018 at 09:31 PM. |
07-06-2018, 10:54 PM | #4 | |
| Re: How much slack is allowed between the c-hub and knuckle? Quote:
So, the bottom line is that it shouldn't be any slack there? Thanks, guys! | |
07-06-2018, 11:41 PM | #5 |
In my axle builds I used a combination of those on the top location and Axials on the bottom. The Axials are very thin, and not made of bronze - I think they are steel. I was using different brands of components than you, my parts tolerances are not going to be the same as you will experience. I also used shims on one set and slightly filed and sanded down the other set to get a perfect bind-free fit without any noticeable play. |
07-07-2018, 11:37 PM | #6 |
I guess, I have found the problem! I took off the wheels and turned the truck upside down for some maintenance... Blue thread lock + tightening and much better! |
How much slack is allowed between the c-hub and knuckle? - Similar Threads | ||||
VP 8 degree hub\knuckle | Leaderbeanjr | Axial SCX-10 | 2 | 03-28-2015 01:00 PM |
knuckle and C-hub compatibility | m0nster | Axial Wraith | 1 | 06-19-2014 04:58 AM |
Knuckle C-Hub question | schmaged88 | Axial AX-10 Scorpion | 3 | 04-22-2013 10:07 PM |
knuckle tight on c-hub | Wicked Klown | Axial AX-10 Scorpion | 23 | 02-16-2011 10:46 PM |
