08-15-2016, 03:32 PM | #1 |
| New Chromoly AR60 Rear Axle Shafts
New rear axle shafts for all AR60 axles are available now! Made from high quality heat treated chromoly steel. Low price and available now! AR60 Rear Axle Shafts - Vanquish Products |
08-15-2016, 03:38 PM | #2 |
| Re: New Chromoly AR60 Rear Axle Shafts
It's about damned time someone came out with axles that aren't just lighter but stronger than stock. Good job VP! |
08-15-2016, 03:38 PM | #3 |
I joined the Band! Join Date: Jun 2016 Location: NY
These will fit a RR10 Bomber? Sent from my SM-G920V using Tapatalk Last edited by THX_138; 08-15-2016 at 06:35 PM. |
08-15-2016, 03:43 PM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Ordered on Saturday Hard to beat an upgrade that costs basically the same as stock.
08-15-2016, 03:55 PM | #5 |
| Re: New Chromoly AR60 Rear Axle Shafts |
08-15-2016, 03:58 PM | #6 |
Awesome! I'm subbed to your YT, when is the next bomber budget build episode? Sent from my SM-G920V using Tapatalk Last edited by THX_138; 08-15-2016 at 06:36 PM. |
08-15-2016, 04:17 PM | #7 |
Quarry Creeper Join Date: Aug 2015 Location: canton,oh
2 sets ordered up plus $10 for shipping :-(
08-15-2016, 04:21 PM | #8 |
08-15-2016, 04:21 PM | #9 |
I feel little better.....or not so bad lol Sent from my XT1565 using Tapatalk |
08-15-2016, 05:06 PM | #10 |
Yeah $9 shipping whether you get a servo clamp or a set of wheels. VP sends everything in the same box the same speed.
08-15-2016, 05:07 PM | #11 |
08-15-2016, 07:06 PM | #12 |
Newbie Join Date: Aug 2016 Location: Riverside
Are the available for the center diffs as well? Sent from my iPhone using Tapatalk |
08-16-2016, 01:01 AM | #13 |
08-18-2016, 06:40 PM | #14 |
Well done |
08-18-2016, 09:07 PM | #15 |
Wow. Yup, need those.
08-18-2016, 11:25 PM | #16 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
They look thicker. I'm curious if/how these will work with Beef Tubes.
08-19-2016, 08:08 AM | #17 | |
| Re: New Chromoly AR60 Rear Axle Shafts Quote:
I would have like to see the inside flange tapered as well, that's exactly where I've snapped every rear axle. Not nearly as much of a concern with the added diameter though. | |
08-19-2016, 08:24 AM | #18 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Re: New Chromoly AR60 Rear Axle Shafts I just got a rear vanquish axle. Very very beefy looking. Thicker than the stock axial. I didn't take a micrometer to it yet but looks like a very nice piece. The axle flat tang that goes into the spool is a bit longer which is awesome. Can't wait to install it
08-19-2016, 11:26 AM | #19 |
I'm not sure about ID on Beef Tubes; but, when installing the stock axles with them, you have to grind the inside flange down quite a bit. This makes me curious to know if the OD of this VP chromoly axle is bigger than the ID of the Beef Tube. Just from looking at the pictures here, It appears to be substantial enough to be close. edit: I just realized that the flat tang is probably the same size as the diameter of the axle. Therefore Beef Tubes shouldn't be an issue after grinding the flange all the way down. Last edited by powder4breakfast; 08-19-2016 at 11:30 AM. |
08-21-2016, 09:02 AM | #20 |
The tang is 4.5mm, the OD of the shaft is 4.75mm. Beefy.
