10-10-2016, 11:56 AM | #1 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
| What pair of foams to replace the stock bomber foams?
Hi All, Do i get the regular or "tall" duces wild foams for the stock tires of my bomber kit? Or what other foams do you guys recommend? I notice that the stock foams are real weak and the sidewalls roll over real easy. Last edited by nd4spdbh; 10-10-2016 at 12:00 PM. |
10-10-2016, 12:33 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: What pair of foams to replace the stock bomber foams?
The Axial 2.2 BFG KR2s use 2.2 Standard Deuces Wild foams. If you want a 2 stage foam, 5.5 DDs are the ones to get. |
10-10-2016, 01:36 PM | #3 |
Do the duces wild allow for enough give though for the tire to conform around rocks when crawling?
10-10-2016, 01:52 PM | #4 |
I'm also considering Double Deuces foams for my stock KR2 tires. The stock foams just allow a little too much sidewall flop. I am just not sure which foam width or stiffness to go with.
10-10-2016, 02:03 PM | #5 |
Or should i look at something like the double deuce, 5.5 comp cut with a medium outer? Question is, do i get the narrow width or normal in the double deuce 5.5? |
10-10-2016, 03:17 PM | #6 | |
Newbie Join Date: Feb 2016 Location: Batavia
| Re: What pair of foams to replace the stock bomber foams? Quote:
If you're looking for pure rock performance double duces are the way to go. They conform around the rocks great and the hard inners help a lot. It's more ture to the 1:1 crawlers, they still run a few psi in their tires. The outer foams will absorb water. So you don't want to let the water sit in the foams. I put holes in the center of the tires and full throttle and the tires spinning get 90% of the water out. I'd also stick with standard 5.5 size. Sent from my VS990 using Tapatalk Last edited by Ctremblay66; 10-10-2016 at 03:20 PM. | |
10-10-2016, 04:25 PM | #7 |
So standard double duces comp cut medium would fit the stock bomber tires well? or the narrows?
10-10-2016, 04:26 PM | #8 | |
Sent from my VS990 using Tapatalk Last edited by Ctremblay66; 10-10-2016 at 04:29 PM. | |
10-10-2016, 04:40 PM | #9 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I'd get the narrower one if the clamping ring area is 1" or less, if the clamping ring area is greater than 1" then I'd get the wider version. The weight of the rig, should give you a ball park area of which firmness of outer foam you need/want. |
10-10-2016, 04:45 PM | #10 |
You want standard width for kit wheels. The narrow width is very narrow and intended for wheels like VP's pizza cutters. Good choice on the comp cut and mediums. |
10-11-2016, 08:58 AM | #11 |
| Re: What pair of foams to replace the stock bomber foams? |
10-11-2016, 09:13 AM | #12 |
Quarry Creeper Join Date: Apr 2008 Location: dallas
crawlerinnovations.com?
10-11-2016, 09:22 AM | #13 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
10-11-2016, 10:23 AM | #14 |
just didnt know if there was a cheaper place (free shipping etc)
10-11-2016, 10:36 AM | #15 |
