07-05-2017, 10:00 PM | #1 |
Quarry Creeper Join Date: Oct 2016 Location: Hanover
| The F100 Bomber
Sup Fellas, I did 3 build threads on this forum already and unfortunately photobucket decided to charge some money to link to them so those build threads are now useless without the pics. So I'm taking this opportunity to test out this site, imgur.com, since it was recommended by some here. So with 3 different Bombers in the house, I wanted to try different bodies to differentiate them a bit. Already did the Pro-Line Jeep Body for the B1B, which did not require much modification and turned out great. We searched around for some more ideas and saw a member named "hemistorm" use a Pro-Line 66' F100 for his Bomber and it looked badass! So naturally, this is what we chose. This is my sons solid axle Bomber which is heavily modified. It does a decent job of keeping up with the B1B and B2B on high speed chase, and this rig crawls very nicely and is very durable. So, I thought we give it a shot and here is how it turned out. Let me know what yall think My paint skills do not compare to hemistorms, but all in all, very pleased with the look. Currently running with TwinHammers length TAs, and I'm thinking it would look better with Wraith length TAs. I really like the current wheelbase at 14", so if we switch, we would have to shorten the front links to keep the WB. This logo was actually a bitch to do, but happy with the results Yall remember those truck visors that were popular in the 90s? Here's an attempt to recreate...actually, I had to do this b/c the front roof line was much higher than the top of the cage, so something to this effect is necessary to hide the gap. Using 12 total "rare earth magnets" glued on to hold the body in place. Feels real sturdy - No body clips necessary. We'll see after some good wheelin' Countersunk magnets and sheet metal strategically placed for the body magnets to cling on to. Last edited by *Old*; 07-06-2017 at 10:47 AM. |
07-05-2017, 10:09 PM | #2 |
Newbie Join Date: Jun 2017 Location: USA
| Re: The F100 Bomber
That's awesome. I like the magnet idea. If you own a smartphone, you can use the Tapatalk app to post pictures to the forum. It's the easiest way I've found. What rear upper links are needed to run twin hammers trailing arms? I might go that route myself. Sent from my S60 using Tapatalk |
07-05-2017, 10:25 PM | #3 |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
| The F100 Bomber
Sweet build! Awesome job with the logo! x2 for using the Tapatalk app to post pictures to RCC. It can also re-size the files for you. Much easier than photobucket -- which was a pain in comparison. Plus the forum is probably more invested in keeping your thread pictures available! Hemistorm also has a YouTube channel if you're interested: https://m.youtube.com/user/hemistormrc Sent from my iPhone using Tapatalk Pro Last edited by Thloftus; 07-05-2017 at 10:32 PM. |
07-06-2017, 05:07 AM | #4 |
Quarry Creeper Join Date: Jun 2004 Location: Louisville
| Re: The F100 Bomber
Very nice! I've seen people using magnets for the body before, although not on a Bomber...which undeniably gets used in much rougher terrain than many other vehicles. Let us know how it holds up.
07-06-2017, 08:05 AM | #5 |
| Re: The F100 Bomber
That's different. It looks cool!
07-06-2017, 11:26 AM | #6 | |
| Re: The F100 Bomber Quote:
To make the TwinHammers length TAs work, use the Wraith length links for the rear uppers. I got them from VP, 3/16" titanium. Kinda pricey, but no issues so far. VP Wraith upper rear links There are other lower costing options though. And thanks for the heads up on the Tapatalk. My Iphone is old school with 16 gigs of memory and it's pretty maxed out, so I can't really download new apps on there. Maybe one day when I upgrade. | |
07-06-2017, 11:29 AM | #7 | |
But anyway, that's a great video. His finishing skills is another level . | |
07-06-2017, 11:32 AM | #8 | |
But I will report back after the first run with this new body. | |
07-07-2017, 11:10 AM | #9 |
| Re: The F100 Bomber Current Parts List: Electronics: Motor - Holmes Hobbies BL540 3500KV Sensored Brushless WP ESC – Castle Mamba Monster X Servo – Savox 2290SG with Axial Alum 25T horn Batteries - Various 5000mah 3S lipos Tranny: Pieced together SuperShafty Bombproof Wraith with DMG Adaptor Robinson Racing X Hard 5mm 12T Pinion with reducer sleeve Axles: Rear – SSD Yeti Wide Diamond with Skid and HD axles Axial 43/13 UD Gears LockedUp RC FI Spool VP 225 SLW Hubs Front – VP AR60 V.2 VP Scale Chubs and Knuckles VP ¼” SS Tie Rod and Drag link Stock Axial Unis Dlux Truss with Servo mount Axial 38/13 Std Gears LockedUp RC FI Spool VP 600 SLW Hubs HR 12mm Hex Clamping Hubs DMG Axle Skid Drive Shafts: Front – Axial WB8 HD Rear – Traxxas T-Maxx Shafts Shocks/Suspension Links: Front Shocks– Gmade Piggyback XD 93mm with Pro-Line Powerstrock Slash Front dual springs Rear Shocks– Traxxas GTRs XX Long with Assoc Factory Team 13mm springs Front Links – VP Stainless Steel upper and lower links Rear Links – VP Titanium upper Wraith Length JEC Trailing Arms Twin Hammer Length VP Currie Anti-Rock SwayBar V.2 Wheels/Tire: Pro-Line Faultline Beadlocks 2.2 Pro-Line TSL XLs 2.2 Misc: JEC Rear shock mount/gas tank relocator DMG Spare Tire Carrier Pro-Line 66’ Ford F100 Lexan Body Team KNK SS Screws Fast Eddy Bearings |
07-10-2017, 10:43 AM | #10 |
| Re: The F100 Bomber
Regarding the magnets - Happy to report, the magnets held the body on like a champ. Did some high speed racing around loose dirt at this new development area near my home. Must've rolled this rig multiple times and high jumps, and the magnet held solid . So I approve of this method. Unfortunately, the Pro-Line Faultline beadlocks on my B1B Bomber gave way and ended the fun Easy fix, but I may have to look into better beadlock wheel options in the future |
07-10-2017, 10:44 AM | #11 |
| Re: The F100 Bomber
Great photos! The blown tire looks kinda real. Did you have the tires filled with green slime? Your body suddenly changed colors! |
07-10-2017, 11:04 AM | #12 |
| Re: The F100 Bomber hahaha - I had 3 rigs out with my boys and we were competing/racing. The B1B kicking ass until it blew a bead and ended the day.
07-12-2017, 03:12 PM | #13 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Re: The F100 Bomber
Can you snap a photo of your rig without the body on so I can see what the TSL XL look like on a stock body bomber? I'm trying to decide if I want that size or the standard 2.2 TSL On another note, this thread was one of the threads that bumped me into buying a bomber over a wraith, kick ass truck. |
07-12-2017, 09:08 PM | #14 | |
Here you go! Naked Bomber: Although I agree the Bomber is probably a better overall rig than the Wraith, and the Kit version comes with a lot more with Bomber. But don't sleep on the Wraith, it has some slight advantages over the Bomber, especially in the crawl dept with it's higher belly, shorter WB, and standard 4 link suspension. But the Wraith doesn't handle high speeds as well as the Bomber, even with similar specs. Good luck! Naked Wraith: Fully Clothes Wraith: | |
07-13-2017, 06:52 AM | #15 | |
thank you, looks kick ass. I'm gonna tinker with the bomber. At the very least it looks like I'll be shortening the wheelbase with TH length trailing arms, that should help the crawlability some. I also have a wraith skid laying around, I may try it and some wraith links and see how the bomber does with true triangulated 4 link. Thanks again for the pictures. | |
The F100 Bomber - Similar Threads | ||||
Making Crawling bomber into trail rig bomber. | theTman | Axial RR10 Bomber | 2 | 06-10-2016 01:46 PM |
