11-28-2017, 06:28 AM | #1 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Spare tire location / removal
I built my bomber cage last night and I can't make up my mind on the spare tire location. I have the DMG relocation bracket and the DMG exo radiator mount but it seems like a tight fit. The bracket also squeezes my fuel line. Can you guys post pics of différents setups? Stock vs DMG vs JEC Racing vs No spare? Sent from my Nexus 6 using Tapatalk |
11-28-2017, 10:33 AM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Spare tire location / removal
You could flip the rear part of the cage upside down, and attach half of the stock spare mount. Sent from my Nexus 5 using Tapatalk |
11-28-2017, 10:34 AM | #3 |
| Re: Spare tire location / removal |
11-28-2017, 11:16 AM | #4 | |
| Re: Spare tire location / removal Quote:
I hope that wasn't too confusing. Sent from my Nexus 5 using Tapatalk | |
11-28-2017, 11:45 AM | #5 |
I think I will go without the spare for the moment. It looks naked without but at least you can see the fuel cell / radiator details Sent from my Nexus 6 using Tapatalk |
11-28-2017, 12:25 PM | #6 |
11-28-2017, 02:27 PM | #7 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
I made a custom deck lid and removed the spare want to make a body panel for where the spare mount was. Want to paint the fuel cell and it will really pop then. Last edited by NitroDarwin; 11-29-2017 at 05:11 PM. |
11-28-2017, 07:35 PM | #8 |
That's a somewhat large image................. (hint-hint)
11-29-2017, 03:44 AM | #9 |
11-30-2017, 09:56 AM | #10 |
Newbie Join Date: Oct 2016 Location: Dallas
I like mine a lot better without the spare on, and I feel like it helps it flip over less without that extra weight up so high.
11-30-2017, 10:12 AM | #11 |
11-30-2017, 06:01 PM | #12 |
11-30-2017, 07:07 PM | #13 |
Remove that anchor. There's absolutely no reason for it other than looks. In the real world racers aren't going to drag around spare tires unless they absolutely need them.
11-30-2017, 09:36 PM | #14 | |
RCC Addict Join Date: Dec 2014 Location: So Cal
The problem is the size of the tire. 5-1/2" + tall tires don't scale at either 1/10 or 1/8, which is what the Bomber actually is if you start measuring stuff and comparing it to reality. So, maybe 3d print some fix a flat bottles and have a win/win situation?? (Note sarcasm) Bummer that there aren't many options for a cool looking and performance solution. That deck cover in the pic a couple of posts above^^^^^ looks good, but I'm biased towards bodywork. Makes me like the SCORE tires I'm running that much more by being 3/4" shorter, scaling out to a 39" tire. That is reality. For what its worth, that 39" tire with a Method beadlock weighs about 160 lbs in the real world. Scale that out, maybe leave the spare for the chase rig to carry. | |
12-01-2017, 06:32 AM | #15 |
I guess it's why many owners put 1.9 wheels and tires on their bomber? Sent from my Nexus 6 using Tapatalk |
12-01-2017, 07:59 AM | #16 |
Yep - to make them more closely resemble the 1:1 Randy Slawson King of the Hammers championship winner... Last edited by durok; 12-01-2017 at 08:04 AM. |
12-01-2017, 12:19 PM | #17 | |
I don't understand your sarcasm though. I didn't say anything incorrect. | |
12-01-2017, 12:49 PM | #18 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
I went through this ordeal over several months and numerous other changes to my vehicle. I tried stock, modified (DIY), DMG and finally naked. Performance with a spare = DMG for the win. Performance as priority #1 = Naked. * STOCK * [IMG][/IMG] -------------------- * DIY * I built this based off an idea from bilinvic. This in essence slid the spare tire up an inch or so making it drag less [IMG][/IMG] -------------------- * DMG * The DMG mount was much better than the DIY and totally got the tire out of the way from dragging on steep approaches [IMG][/IMG] [IMG][/IMG] This one shows just how high it sits when on steep terrain [IMG][/IMG] -------------------- * NAKED * Eventually performance won me over. I had an SSD Rock Racer rim and Pro-Line Flat Iron tire for matching spare [IMG][/IMG] This combo was pretty heavy and pretty high. Leaving it low drug like an anchor and keeping it high hurt COG. I tested with and without several times on the same technical obstacle and the difference was unmistakable. Probably not a big deal for more than 90% of fun crawling; but, the negative effect on really steep angled techy spots was absolutely noticeable. So I ended up ditching it altogether [IMG][/IMG] [IMG][/IMG] Last edited by powder4breakfast; 12-01-2017 at 12:52 PM. |
12-01-2017, 01:30 PM | #19 |
Those are the same reasons I run mine naked. also, nice rig. Sent from my Nexus 5 using Tapatalk |
12-02-2017, 05:47 PM | #20 |
So where is the trade off? Having the weight out back for traction or the high cg lever up there trying to tip you over? Anyone running shorter tires having the same problem? I'm not up and running yet so no dog in the fight. It appears that in most of the pics/videos I've seen that axle clearance isn't the problem, rather keeping the rubber side down. Maybe a 1/8" thick steel skid would solve some of that problem??? Try some mag weights? Seems most everyone gets an hr of run time on a 3s, .60 lb skid. Granted, my build is out in left field to the norm, I will try all kinds of things if needed. Most of the peeps here seem to be weekend warriors rather than competitors anyhow. Amaze your buddies by toting that spare tire and still keep it wheels down. |
Spare tire location / removal - Similar Threads | ||||
Spare Tire Location | atomichead | Axial Yeti XL | 1 | 09-01-2017 06:26 AM |
spare parts,,spare tire rack,,, | dezmoon | Tamiya CR-01 | 4 | 09-10-2008 05:54 PM |
