03-25-2018, 09:18 AM | #1 |
Newbie Join Date: Feb 2018 Location: marion
| rr10 trailing arm swap
Does anyone have info on where and what specifically to order to shorten wheelbase in the rear? specific part numbers prefered, thanks. I hate guessing when its been done and proven |
03-25-2018, 09:24 AM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: rr10 trailing arm swap
Wraith driveshaft, wraith rear upper links and wraith trailing arms Some go even shorter with twin hammer trailing arms but i think you need custom upper links and a custom cut driveshaft. If i ever break my trailing arms, i might go wraith lenght. Last edited by Jboucher; 03-25-2018 at 11:30 AM. |
03-27-2018, 08:14 AM | #3 |
Rock Stacker Join Date: Jan 2016 Location: farmington
why you guys going shorter? looking to crawl ilo bash? curious if the rr10 would rip around while maintaining stability with shorter rear arms
03-27-2018, 08:21 AM | #4 | |
| Re: rr10 trailing arm swap Quote:
You would lose stability for sure. Sent from my Nexus 6 using Tapatalk | |
04-17-2018, 04:28 PM | #5 |
After looking at another thread with pictures, the Twin Hammer trailing arm make the bomber look SO MUCH BETTER for scale. It brings the read end under the fuel cell and it's much closer to the real Bomber 1:1. If you remove the spare tire it's even more apparent. I'm thinking of going to Wraith trailing arms for the look alone... |
Tags |
rr10 wheelbase mod |
rr10 trailing arm swap - Similar Threads | ||||
Trailing arm length | Cultus | Losi Rock Rey | 5 | 09-01-2017 05:57 PM |
Question About RR10 Bomber Transmission Swap | K.C.'s RV | Axial RR10 Bomber | 11 | 08-02-2016 07:53 AM |
trailing arm links | mookie | Redcat Crawlers | 6 | 07-07-2010 06:43 PM |
