05-18-2018, 05:38 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Servo saver or aluminum horn
As title says. Should i get some type of servo saver or run aluminum servo horn? Sent from my Moto Z (2) using Tapatalk |
05-18-2018, 05:47 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Servo saver or aluminum horn
VP clamping Horn and servo mount. If you really want a servo saver, use the Pro-line Big hit. Sent from my Nexus 6 using Tapatalk |
05-18-2018, 06:07 PM | #3 |
Rock Stacker Join Date: Jan 2017 Location: Chicago
I have both. After the upgrades, (VP Axles, SS Links, VP Wheels, c-hubs, knuckles) the Savox 1210 could not bare the pressure. Got a PL Big Hit and quit stripping the gears out of the Servo. Steering is a bit sloppy now, but I think it is manageable. Sent from my Moto Z (2) using Tapatalk |
05-18-2018, 07:18 PM | #4 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
If your just crawling and trail riding, get the aluminium horn. If you got a fast setup and will be jumping and crashing often, then you'd need the servo saver. Sent from my SAMSUNG-SM-G920A using Tapatalk |
05-18-2018, 08:12 PM | #5 | |
| Re: Servo saver or aluminum horn Quote:
Exactly. And set your end points correctly. A servo saver is sloppy for precise steering lines. Hang up and Drive | |
05-21-2018, 03:56 AM | #6 |
Quarry Creeper Join Date: Sep 2017 Location: UK
Be warned with the proline bighit jobbie that its M3 rather than M4 thread on the ends. I modded mine with some m4 threaded rod.
05-21-2018, 07:23 AM | #7 |
Servo savers and slipper clutches don't belong in crawlers IMO. If you're bashing it's a different story.
05-21-2018, 08:31 AM | #8 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
I just mentioned this in another thread... the slipper in my Spawn kit works perfectly. No maintenance. Sslips only when one of the wheels wheel is working against another.
05-22-2018, 05:13 PM | #9 | |
My $.02, Sent from my Moto Z (2) using Tapatalk | |
Servo saver or aluminum horn - Similar Threads | ||||
servo horn saver/arm for txt1/2 | Spiff | Tamiya Txt-1 and Juggernaut | 2 | 01-25-2016 03:11 AM |
home brew servo horn saver, for those with wacky steering | Cam_L | Redcat Crawlers | 5 | 02-14-2010 10:24 AM |
