01-03-2022, 01:31 AM | #1 |
Newbie Join Date: Jan 2022 Location: Fairbanks
| Bomber IFS?
Anyone have any idea if you can put ifs on the bomber? I know that you can for the scx10, but could someone point me in the right direction for the bomber IFS?
01-03-2022, 06:57 AM | #2 |
Pebble Pounder Join Date: Oct 2019 Location: Saint Louis
| Re: Bomber IFS?
Maybe just start with an Axial Yeti? It’s got the same rear axle as a bomber Sent from my iPhone using Tapatalk |
01-03-2022, 09:14 AM | #3 |
| Re: Bomber IFS?
Death Metal Garage (DMG) used to make the B1B IFS kit - he has a FaceBook page - since I don't, I'm not sure if he still does, worth checking out though!
01-03-2022, 09:48 AM | #4 |
| Re: Bomber IFS?
Yeah, DMG has the conversion kit you want. He is up to somewhere around 100 conversion kits made at this point and I happen to still have kit #4. There is a thread on that build somewhere in the depths of the Bomber section.
01-04-2022, 08:49 AM | #5 |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: Bomber IFS?
X3 for the DMG kit, Jerry was the only guy making them that I am aware of, using Yeti and Exo front end parts so you can keep with 2.2 wheels. Check for parts availability and build cost before you get too deep into this idea. I believe Slash 4x gearing is very close, but you will be running 2.2-3.0 wheels to clear the c blocks. JConcepts made a kit for 2.2s to clear, but is a unicorn to find. If you are a fabricator, it is a relatively simple skid extension with the mounting arrangement for the IFS you choose to run. Do know you will be cutting some of the cage structure off for clearance, so once you start, there is no going back. Do note that steering angle sucks with IFS, like comparing my Ford Ranger to my Ford crew cab dally turning radius. Makes for an excellent trail runner rig. Google DMG B1B Bomber. https://www.facebook.com/21574695863...1682423042207/ |
Bomber IFS? - Similar Threads | ||||
1.9 IFS Bomber | ScaleReady | Axial RR10 Bomber | 12 | 02-07-2019 07:15 PM |
Hwin ifs bomber | erickhe | Axial RR10 Bomber | 17 | 05-22-2018 12:31 AM |
My IFS Bomber Build | *Old* | Axial RR10 Bomber | 176 | 07-10-2017 11:13 AM |
