04-18-2022, 08:52 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Mudville
| Front axle shafts. VPs Incision SSD
Which would you go for? I like the VXDs having the 60* turning radius available without modding. But the VVCs look pretty good and are 5mm shafts. Then they offer the Incision option. I have had really good luck with SSD gear in the past. Which would you go for? Why? Given on the steering angles. |
04-18-2022, 10:12 PM | #2 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: Front axle shafts. VPs Incision SSD
I use incision VDI's... chromoly universals... simple and strong.
04-19-2022, 03:56 PM | #3 | |
| Re: Front axle shafts. VPs Incision SSD Quote:
I see the Incisions are about 67, but no locker. Out of stock atm at Amain. I see the VPs VVDs are 87, but again, no locker. which by the time you add it, is nearly the cost of the VXDs. However the VXDs have way more turning radius with no modding needed, unless the chubs/knucks need to be whittled on a bit for more turning radius. Thanks for the info. Last edited by Timmahh; 04-19-2022 at 04:00 PM. | |
04-19-2022, 04:48 PM | #4 |
Rock Crawler Join Date: Aug 2005 Location: Augusta
If it matters, your tires will be into the links, and the steering rod ends hitting the housing before you're able to use anything more than about 50°. I just use the axial ocp universal shafts and they have been fine. Split an iron cross locker in half and the shafts are good still. |
04-19-2022, 06:16 PM | #5 | |
Good info. I wouldn't mind saving a lil money, but 20.00 isn't really anything to fret over... Hmmmm | |
04-19-2022, 07:40 PM | #6 |
Rock Crawler Join Date: May 2012 Location: Columbus
I just picked these up waiting for a t# still https://dluxfab.com/5mm-FBA-Axle-Sha...ngth-p68505113 |
04-19-2022, 08:08 PM | #7 | |
06-04-2022, 01:00 PM | #8 | |
Rock Crawler Join Date: Sep 2015 Location: Lake Stevens
How did you like the Dlux shafts? Looks great for $60 if they perform well and hold up over time. Sent from my iPhone using Tapatalk Pro | |
06-04-2022, 01:02 PM | #9 |
Pls ignore this one - posting error
Front axle shafts. VPs Incision SSD - Similar Threads | ||||
Which drive shafts? Incision or SSD. | cul8tr | Axial SCX10 II | 4 | 11-28-2019 08:33 AM |
Coming Soon the NEW SSD SCX10 II CVD Axle Shafts! | RPP Hobby | RPP Hobby | 0 | 10-30-2018 04:36 PM |
SSD Diamond front axle | waka789 | Axial SCX-10 | 3 | 08-29-2016 12:36 AM |
SSD front axle shafts | shiftauto | Axial SCX-10 | 4 | 08-19-2016 09:38 AM |
New SSD Rear Axle Shafts for D60 Wide Axle (XR) | SSD | Axial SCX-10 | 0 | 05-17-2016 10:51 AM |
