08-18-2016, 11:00 PM | #1 |
Rock Crawler Join Date: Mar 2016 Location: HB
| SSD front axle shafts
Took the Rubi out for its first run in a while after installing the ssd front axles. Get it back home and notice this... I thought these shafts and the vp stage one kit would play well together. Anyone run into this issue before? |
08-18-2016, 11:02 PM | #2 |
| Re: SSD front axle shafts
It could've been worse, found the issue when the rig almost burned down!! |
08-19-2016, 12:59 AM | #3 |
| Re: SSD front axle shafts Common my VVDs have the same mark. Shave down the end of the knuckle screw slightly. It's probably the bottom screw look close and you should be able to see.
08-19-2016, 08:48 AM | #4 |
Thanks fr8cture, I'll grind it down after work today. Everything spun freely when I installed the shafts but it was on the stand so it wasn't under load.
08-19-2016, 09:38 AM | #5 |
| Re: SSD front axle shafts |
SSD front axle shafts - Similar Threads | ||||
SSD Diamond front axle | waka789 | Axial SCX-10 | 3 | 08-29-2016 12:36 AM |
New SSD Rear Axle Shafts for D60 Wide Axle (XR) | SSD | Axial SCX-10 | 0 | 05-17-2016 10:51 AM |
front axle shafts | derekshep | Tamiya XC/CC01 | 2 | 03-08-2010 11:40 AM |
