Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: SCX-10 Body Comparison (lots-o-pics)
Old 02-11-2009, 12:47 PM   #1
Mriswith's Avatar
Default SCX-10 Body Comparison (lots-o-pics)
Since I got my SCX-10 I've been trying to figure out what body to run. I'm not the only one So I grabbed most of the shells I have laying around and took some pics to see what works. The wheelbase is stock
Proline C-10
Axial RTR body
Stock TXT Body
Proline H1 Hummer
Proline H2 Hummer
Proline Suburban
Parma Grave Digger
Grave Robber (Just because it was laying around)
Stock(?) Savage Body
And lastly, the Rubicon body
Mriswith is offline   Reply With Quote
Old 02-11-2009, 01:29 PM   #2
Umm...wow...you sure have a lot of shells laying around!
goldmember is offline   Reply With Quote
Old 02-11-2009, 01:38 PM   #3
j0e
hmm, the jeep looks pretty good on there. just stretch it a little.
j0e is offline   Reply With Quote
Old 02-11-2009, 01:39 PM   #4
Crawling is a fad...
Nerve's Avatar
proline C10 would be my first choice
the gravedigger body doesnt look to bad on there...
Stock savage looks rather goofy on there
Otherwise the Rubi if it can be adjusted.
Nerve is offline   Reply With Quote
Old 02-11-2009, 02:26 PM   #5
701 Technique's Avatar
I see you got your SCX-10, you going to start a build thread?
The stock TXT body seems to fit the wheelbase
701 Technique is offline   Reply With Quote
Old 02-11-2009, 05:09 PM   #6
Mriswith's Avatar
I just threw these up so others can get an idea of what bodies would fit
I didn't bother with the MGT sized Proline F250, stock WK body, Parma Dakota, Wally World JK hardbody or the Golf Cart. And of course the Nylint 6th scale Jeep and Scorpion bodies would have just been silly
I'm not using the Rubicon or any other body that requires stretching. Now I may cut down the Hardbody to fit the stock wheelbase
I'm seriously thinking about the C10 but only with tube work. You almost have to shorten up the Grave Digger body but thats for one of my TXTs. The savage body does look goofy, low roof line and really long bed. The fender are to big on the Rubicon body, might use it on a 2.2 but not this 1.9
I'll start the build thread when it's warm enough braze up some tube work. I've got to out do what I did for Tony. That and decide what body to use. The only one of these I MIGHT use is the C10.
Old 02-11-2009, 05:41 PM   #7
Too bad you didn't have an F-100 or Bronco to try out
fordmike65 is offline   Reply With Quote
Old 02-11-2009, 06:05 PM   #8
does anyone know if the proline f-250 bodies would need a wheelbase strecth or the f-100 thanks
gixxer750 is offline   Reply With Quote
Old 02-11-2009, 06:32 PM   #9
f-100 should be about right, may need a half an inch strecth, but the 250 will more then likely need a strech
Terminator13 is offline   Reply With Quote
Old 02-11-2009, 06:33 PM   #10
500swmag's Avatar
1st- C-10 with some fender flares
2nd- grave robber, just cause it would be a bit different than most.
500swmag is online now   Reply With Quote
Old 02-11-2009, 06:38 PM   #11
That Grave Digger would look hot.
I am going to try a Descender on mine when I get one.
renoirbud is offline   Reply With Quote
Old 02-11-2009, 07:15 PM   #12
Mriswith's Avatar
I REALLY want to try the Bronco but I don't have one laying around. It's the only one I don't seem to have laying around. I've been wanting to do another one and it would be really close to just drop right on this wheelbase.
If the Grave Robber was a little wider I would definately set it up a spare body just to be really different. EVERYONE uses the Jeep bodies which is why I'm staying away from them if I can help it. I might even look at the Scouts before they get too popular
The fenders on the Grave Digger are too big and flared for my tastes but it would be different
Old 02-12-2009, 01:32 AM   #13
I've had the stock TXT body for about 5 years now, just sitting in the shed. I cut up the spare beyond repair 'experimenting.' Now thanks to you, I have a basher body. With very, very minor trimming, I just mounted it, and will be painting it tomorrow after work.
FROADER is offline   Reply With Quote
Old 02-12-2009, 01:57 AM   #14
C10 looks good, would be my first choice, second the Rubi wish it fit better though.
Goose is offline   Reply With Quote
Old 02-13-2009, 04:20 PM   #15
As I allready mentioned in another post , The HPI Defender is a perfect fit , too .
rockopa is offline   Reply With Quote
Old 03-02-2009, 10:08 AM   #16
is the grave digger body that tall or did you have trim off a lil less in the front and sides?
NeXt559 is offline   Reply With Quote
Old 03-02-2009, 12:27 PM   #17
Mriswith's Avatar
I didn't trim the Grave Digger to the body lines, just the wheel openings. There is about 1/4 inch extra on the sides, 1 1/4 extra on the front and 3/4 more on the back.
It's setting with the side body line about level with the bottom of the chassis. It would trim out to be just slightly smaller than the Suburban body but with a shorter W/B. You wouldn't notice the size difference without having both in hand.
Old 03-02-2009, 03:33 PM   #18
That C10 looks great, I know what I am going to order
rm25x is offline   Reply With Quote
Old 03-02-2009, 05:21 PM   #19
I like the C-10 best as well with your set up. Matches nice!
off topic: How did you post pics without a paying account? I have looked for a way to do it but I am stumped. I don't see a star next to your name is why I ask...
JB
CruiserHead is offline   Reply With Quote
Old 03-02-2009, 07:11 PM   #20
Default Rubicon wheel base
The Rubicon body,,,will i need to stretch the wheel base any ?
Osco is offline   Reply With Quote
