03-12-2009, 05:26 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Riverview
| Build Advice Question guys,,The rubber travel limiter bottom of the shock shaft, I assume this is needed ? 2nd ? I cannot find link for a Diff kit to unlock the front axle ? 3rd ? For general trail and light crawling with a 3800 or so Lipo in the rear How much wheel weight in front/rear if any ? 4th ? Is this the coolest outta the box scale Kit or what ?? |
03-12-2009, 05:42 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
1. The limiter is to protect shock from excessive travel, and some people have cut it down to increase articulation that little bit more. 2. Search some of the after market sites for diff gears for the axial axle. I think that some other posts have the actual part number. As others say, "Search is your friend." 3. Not too sure since this is my first crawler. Still experimenting with this myself. 4. Beyond any doubt this has been the most fun kit I have ever assembled. Great quality, and the only problems stemmed from operator error. Outstanding kit. Thank you Axial!!! |
03-14-2009, 09:11 AM | #3 |
Newbie Join Date: Feb 2008 Location: Johnson City
2. I don't have the link, but I belive the part numbers you need are: AX30170 Diff Pins AX30390 Diff Gear Set |
03-14-2009, 11:17 AM | #4 |
Newbie Join Date: Jan 2009 Location: Louisville
1. I just removed my bumpstop alltogether. 3. You are just going to have to play around with this. Will be different depending on where you are driving it. |
