04-24-2009, 12:38 PM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Rockaway
| wheelbase shortened
this is my first scale/crawler so i am enjoying the crawling aspect of it more right now. If i were to shorten the wheelbase bout 1/2 inch would it affect the performance so much i would not like it. just looking for some input. Not a huge deal i can live with out it but think it would look alot better if the wheelbase matched the body. [/IMG] Last edited by hoyt; 04-29-2009 at 01:23 PM. |
04-24-2009, 01:31 PM | #2 |
Quarry Creeper Join Date: Mar 2005 Location: hudson (the big city)
you could always just widen up the wheelwells just a tad.
04-24-2009, 01:33 PM | #3 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
I have the same body for mine and I just opened up the wheel wells like has been suggested already. Still looks pretty scale, just laking the fener flares but you could probably get creative with a heat gun if you really want to have them on there
04-25-2009, 07:28 PM | #4 |
Rock Stacker Join Date: Jan 2009 Location: Riverview
| Hmmm Before I would cut or shorten I would just raise the body 2 or 3 notches,,,,I bet the fender cut would be less severe,,, And for scale crawling I doubt 1/2 less wheel base would be that big of a deal,,,,also shorter wheelbase,,,,tighter turning circle,,possible XD Careful Im still a Noob,,,Did my first scaler,,scx10 and I dig It. |
04-29-2009, 02:00 PM | #5 |
| went ahead and shortened
hey guys thanks for the replies, much appreciated Well I decided to give a go at shortening the wheelbase. I ordered up some 6x74.5mm grey threaded aluminum pipe (ax30479) for the lower links and 7x50mm grey post (axa1427) for the upper links. After putting it together i moved the shock mount to the forward holes on the chassis and had to cut bout 1/4 inch off the drive shaft for it to fit. Amazingly and thank god, cause i did some cutting, it seemed to fit the wheelbase great. The only real big diffierence i have found it performance is that it definitely needs weight in the tires. Because I got the MSD steering kit my battery is mounted in back so the front end really likes to come up now. let me know what u think Before shot [/IMG] After shot New links added and also had to move the Y spacer to the rear to get the right angle on the axle. [/IMG] Here's how it looks and some action shots. Just like taking pictures [/IMG] [/IMG] [/IMG] |
04-29-2009, 02:26 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Nice job, looks great! |
05-01-2009, 08:23 AM | #7 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Nice work, you did the right thing. Now it looks like it should. Widening wheelwells to fit the wheelbase of a chassis never looks right IMO. It may be 5X more work, but shortening the links to make the wheelbase fit the body always looks better than just hacking out the wheelwells. A shorter wheelbase will perform different, but that's part of the scale experience. You can't expect comp crawler level performance out of them... |
05-01-2009, 10:20 AM | #8 | |
05-01-2009, 10:52 AM | #9 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
05-01-2009, 12:13 PM | #10 |
Rock Stacker Join Date: Mar 2009 Location: Los Angeles
yeah... looks a lot better with the shortened wheelbase. more realistic looking.
05-01-2009, 04:15 PM | #11 | |
x2 thank you | |
05-01-2009, 11:53 PM | #12 |
Quarry Creeper Join Date: Oct 2007 Location: KC
Using those axial parts, what did it shorten the wheelbase to? 11"? I might wanna shorten mine for my blazer body....lmk |
05-02-2009, 03:46 AM | #13 |
im at work now and cant check it but i think it was just over 10 3/4 inchs i believe
05-02-2009, 05:38 AM | #14 |
Quarry Creeper Join Date: Nov 2007 Location: NH
I run my rig with a 10 3/4" wb. I don't have a problem with it at all. Granted it doesn't crawl as good as my comp rig but its not supposed to. |
05-02-2009, 07:52 AM | #15 |
Built, not bought Join Date: Oct 2004 Location: Gresham
