06-07-2009, 07:57 PM | #1 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Axial Drive Shaft Set
I broke this plastic Axial Drive Shaft Set the pin cracked right out what is the best upgrade for this |
06-07-2009, 08:24 PM | #2 |
Newbie Join Date: Jul 2008 Location: Jefferson
I replaced mine with traxxas drive shafts. the traxxas part number is 1953. 1951 will work too but they are a little short. http://www3.towerhobbies.com/cgi-bin...8&I=LXJH85&P=K |
06-07-2009, 08:47 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Fresno
mip c spline shafts. by replacing the stock pin w/ a peice of piano wire, they'll be the last shafts you'll buy for the rest of the life of your rig, and then some. if you break these you definatly need an award http://www.shop.rpphobby.com/product...&productId=874 Last edited by NeXt559; 06-07-2009 at 08:54 PM. |
06-07-2009, 09:33 PM | #4 | |
Rock Crawler Join Date: Sep 2008 Location: Portland
No need to replace the pin, I have put mine through hell with no issues | |
06-07-2009, 10:09 PM | #5 | |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
not sure what pin your refering to? The axle pin? AX30163 or the u-join on the drive shaft? AX3080 or the pins on the transmission? AX30162 | |
