07-03-2009, 08:43 AM | #1 |
RCC Addict Join Date: Nov 2007 Location: Massachusetts
| LEAF Springs on an Axial SCX-10 frame
Hey Guys, I've seen quite a few threads on here asking if you can run leaf springs on the Axial SCX-10 chassis.. The answer is YES you can.. I wanted to use the SCX's scale frame for a custom project I'm building, ( which will be un-veiled later on..) and I also wanted to run leaf springs so the first thing I did was pick the axle combo I wanted to run, which was a set of RC4WD's "Ultimate Scale" Toyota axles. The next thing I tracked down was a complete leaf spring, and shackle set from a Tamiya "Hi-lift" truck. After ALOT of careful measuring I knew it was time to modify the frame, and center sections.. The stock frame set-up will NOT work with leaf springs right out of the box.. I needed to ( VERY carefully) BEND in both front and rear ends of the stock chassis, basically flattening out the ares where the spring shackles were going to mount to.. This step is VERY important that each frame rail is bent back to straight ( square) once your all done bending both sides.. If one side is bend even the slightest bit off, it will throw off the entire geometry of the frame, and the truck won't run "true" so to speak. I also had to grind down 1/16" from EACH SIDE of all the plastic stock axial cross pieces,and stock tranny mount/skid to get the correct width for the RC4WD axles. Next step was figuring where I wanted to mount the shackles to the frame. Once its all measured out ( and WB has been decided on) I simply marked the holes on the chassis and drilled them out, then installed the shackles, leafs, and axles. This overall process is pretty time consuming, and must be done correctly for it to work right, but the end results speak for themselves - ( same application applies to a number of other axles you might want to use) Heres compared to stock - And heres an above view.. Notice how much narrower the front and rear is on the leaf spring frame compared to the stock set-up above it. Here you can also see I made the WB the EXACT same as stock. |
07-03-2009, 08:46 AM | #2 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
Very nice Chris.
07-03-2009, 08:51 AM | #3 |
07-03-2009, 12:45 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Mount Holly
Looks real good.
07-03-2009, 01:22 PM | #5 |
Newbie Join Date: Mar 2009 Location: reno
sweet i know what im doing now |
07-03-2009, 03:09 PM | #6 |
Quarry Creeper Join Date: Jan 2007 Location: Cuyahoga Falls
thats what I need to do to my FToy! Looks good!
07-03-2009, 03:26 PM | #7 |
RCC Addict Join Date: Dec 2007 Location: Calgary
It looks awesome Chris, nice job |
07-03-2009, 06:02 PM | #8 |
hay how good do those flex?:?
07-03-2009, 07:53 PM | #9 |
RCC Addict Join Date: Feb 2005 Location: Guam
Chris, as stated above great right up bro! It is a good start for the guys that want to try this setup! Thanks man |
07-04-2009, 11:15 AM | #10 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Looks good, but any chance we can get a closer picture of the detail areas? |
07-06-2009, 11:54 PM | #11 |
thats awsome. i wanna see how it flexes and crawls!
07-07-2009, 02:53 PM | #12 |
Newbie Join Date: May 2009 Location: not-dea
can't wait to see this project unveiled
07-08-2009, 09:23 AM | #13 |
Quarry Creeper Join Date: Jul 2009 Location: Bel Air, MD
If you brought all the rails together, why not simply narrow the centersection instead of bringing the rails in?? Sounds like a fun job for a bodyman! |
07-08-2009, 01:04 PM | #14 |
Rock Stacker Join Date: Sep 2006 Location: Alberta
I love the leaf spring look but I also love the artic. of the four link. good job!! |
07-09-2009, 09:22 PM | #15 | |
| TRUST ME- It will be WORTH the wait..!!!! Quote:
Thanks Justin..!! Once the springs break in, it should flex ok, but its pretty stiff for now. ( The leafs I'm using are brand new and aren't broken in yet) Thanks Man- and Thanks to all those others that commented as well.. There WILL be more detailed pics of the frame mounts, once the "Secret Project' has been unveiled.. but you gotta STAY TUNED for that..!!! | |
07-10-2009, 11:39 AM | #16 |
thanks for the write up always pondered how to do it
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-scx-10/187065-leaf-springs-axial-scx-10-frame.html | ||||
Is it possible to use leaf springs on axial scx10 ? | This thread | Refback | 10-07-2011 07:15 AM |
