07-20-2009, 05:41 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
| SCX-10 articulation question.
I Just finished putting my truck together and drove it about 10 minutes ago. I was wondering if there was any way to get more articulation out of it with out hacking to much. I was also wondering if anyone was running softer springs and if anyone has removed the limiters in the stock shocks? The problem I am having is that before the front tire stuffs in the fender the rear lifts off the ground and flips me over. It climbs great, but anything off camber and it topples. Any help would be nice. Thanks in advance. |
07-20-2009, 05:59 PM | #2 |
Rock Crawler Join Date: Feb 2007 Location: Lorain
Remove the rubber stops that you were suposed to put on the shock shafts. Wont hurt it any it's the easiest way. |
07-20-2009, 06:05 PM | #3 |
Newbie Join Date: Mar 2009 Location: k ville
softer springs will help, also put some weight on the wheels
07-20-2009, 06:30 PM | #4 |
What shock setup do you recommend? Soft/ supersoft ? And should I change both springs to softer springs or just the bottom or top.
07-20-2009, 07:22 PM | #5 |
Quarry Creeper Join Date: Feb 2009 Location: Rocklin, CA
Move the battery low and up front, weight the tires, and change bodies. To get any wheel clearance, you either have to hack the body like crazy or mount it way too high. Read the posts here from when the truck first came out. Lots of build threads have good write-ups with pictures that show a lot of good tips. |
07-20-2009, 08:28 PM | #6 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
the stock springs are about perfect for my setup. i dont have the rubber limiters though |
07-21-2009, 06:21 AM | #7 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I have the stock limiters on my shocks and weighted the tires. I also replaced the stock 40mm green springs with 40mm white springs all around.
07-21-2009, 09:32 AM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
If you're runnin' unaltered stock Axial wheels, they most definitely need some weight. I wrapped mine w/ old dirty solder I did'nt want to actually solder with anymore, until the center groove was full. I'm running the stock green springs, and the limiters on the shafts are cut down 1/8". The stock kit shocks are actually quite acceptable IF you are careful and meticulous about assembling them (they perform 10 times better at high speeds than the RC4WD internal-spring scale shocks I tried for a while - lesson learned is that scale shock boots need to be REALLY flimsy and thin to NOT have an adverse effect on the shocks performance) I flip the springs so the retainer between them is down around the shaft instead of around the shock body, this alone really frees them up because the retainer binds against the shock body as the springs move. |
07-23-2009, 07:42 AM | #9 | |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
Thanks | |
08-15-2009, 03:11 PM | #10 |
Newbie Join Date: Sep 2007 Location: sylmar
I had the same problem. I moved the battery and removed the rubber stops. It worked for me.
08-15-2009, 04:06 PM | #11 |
This is just my opinion but we are talking about a scale chassis and not a purpose built crawler so with that in mind I think the articulation is more than enough out of the box. My SCX will out crawl some custom chassis as it is. I have the battery and electronics all in the front. I feel that any more articulation will detract from the scale appearence and performance. Driving this scaler sure does remind me of driving our full size Broncos, Blazers, FJs, CJs and Ranchargers back in the early 80s. I love the scale performance. If I want extreme crawler than I use my AX-10 outfitted for max crawling. BTW: the stock shocks work rather well. |
08-15-2009, 05:04 PM | #12 |
Newbie Join Date: Apr 2009 Location: Crawlerado!
| scx10 more articulation
I had the same problem. Instead of investing any money into the problem I found a set of stock ax10 shocks. I semi drooped them with a 90% droop 10% sprung (internal springs). Articulates like a champ, just the change I wanted for little money. Have fun with it. I plan to move the steering servo to the frame up front, put the radio/electronic box as a gas tank and the battery behind the servo. |
08-15-2009, 07:53 PM | #13 |
Rock Stacker Join Date: Mar 2008 Location: 734
like everyone else i didnt put those limiters on my shocks when i got mine earlier i moved my battery to the front and removed my foams and put some bbs in my tires and its 100% better. i couldnt put my battery as low as i would have liked but to me recievers height but still works much better |
