11-03-2009, 12:57 PM | #1 |
Newbie Join Date: Nov 2009 Location: Marion
| Kit Links For The TR??????
I think I have finally decided to go with the TR Since lights, bumpers, the body etc etc. But my biggest concern is the plastic steering links and the regular links. Where can I buy just stock ones fro the kit version?? I cannot find any anywhere!
11-03-2009, 02:41 PM | #2 |
I joined the Band! Join Date: May 2009 Location: anaheim
To do it you have to look up all the part #'s from the kits manual which can be found on axials website. It isn't very cheap to switch them to the kits aluminum links btw
11-03-2009, 03:12 PM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Like Proraptor said, it'll get spendy just buying all the links. Probably more than $50. I'd HIGHLY suggest building some yourself out of all-thread and Traxxas rod ends. Do a quick search and you'll find out how to make them on your own.
11-03-2009, 04:19 PM | #4 |
get the steering first if you have to chouse
11-03-2009, 07:51 PM | #5 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
I don't know what all the TR comes with that you can reuse but here is everything I could think of. AXA1429 - upper y link rods AX30516 - tie rod AX30524 - lower link rods AX80015 - upper y link AXA186 - grub screws AX80032 - straight Rod ends AX80018 - balls for rod ends AX80005 - angled Rod ends AXA1418 - spacer on y link |
11-04-2009, 05:55 AM | #6 |
Rock Stacker Join Date: Sep 2009 Location: Hopkins
That parts list is the same one I made for switching out all mine. Looks like you got them all covered there Locked Up. Anyone remember the lengths of the links for the upper links when you add the four link brackets to the axles. I added some Traxxas links I had lying around but they clocked the axle way to much and I'm starting to think this is why my tranny is making noises b/c of the extreme driveshaft angles. I know theres some threads about those supplied four link brackets, I'll take a look-see. |
11-04-2009, 08:13 PM | #7 |
Thanks everybody, especially for that list. Guess I'll just be stuck with what comes with it for awhile I've never custom built anything like that. I've had a mini-t and a Pede other than that I've only had nitros, tryin to sell my savage now if anyone is interested, but really really wanna do a scaler semi crawler thing I think this'll be the truck for me. Just like the Aluminum links so much better.
11-04-2009, 09:48 PM | #8 | |
- Dremel (or similar tool) with cut off wheels - 1/4" .049 wall tube - 6-32 all thread (any hardware store/home depot/lowes will have it) - 3mm Rod Ends - will need to slightly drill them out for the 6-32 all thread. - Balls for rod ends | |
11-04-2009, 10:52 PM | #9 | |
Newbie Join Date: Oct 2009 Location: in the sticks
11-06-2009, 10:31 AM | #10 |
Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
well are there any disadvantages of the plastic links? i can understand the steering link being plastic n having flex but do the other links have any performance drawbacks?
11-06-2009, 12:09 PM | #11 |
| I actually prefer the stock suspension links as they slide over the rocks better. The aluminum steering links are a must!
11-06-2009, 12:36 PM | #12 |
11-06-2009, 03:04 PM | #13 |
11-06-2009, 04:12 PM | #14 |
11-06-2009, 04:49 PM | #15 |
Pebble Pounder Join Date: Jan 2008 Location: westfeild IN
so the ax10 and scx10 have the same axles so i could just get http://rcpcrawlers.com/product.php?p...6&cat=0&page=1 to swap to alu steering correct?
