11-07-2009, 07:55 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Tulsa
| Fed up with scx10 tr driveshafts!
Me and my brothers driveshafts pop off the transfer case almost EVERY time we go out, the screws are taking a beating from being tightened over and over. What is the solution to something like this? And are there replacement screws for the tiny allen head screws? Could I use a light glue in the hole over the screw to give it some extra strength? thanks ahead of time! |
11-07-2009, 07:58 PM | #2 |
Blue threadlock is your friend ;)
11-07-2009, 08:04 PM | #3 |
can i get that at home depot? lol
11-07-2009, 08:14 PM | #4 |
I would think so, or a car parts store, or you could always hit up your local hobby shop:-P
11-07-2009, 10:56 PM | #5 |
good call thanks! ill head to action hobbies tomorrrow
11-07-2009, 11:13 PM | #6 |
Rock Stacker Join Date: Oct 2009 Location: Fort Worth, TX
11-07-2009, 11:34 PM | #7 |
awesome thank you anyone else have this problem with theirs? i searched around on the forums some more and it seems most axials have this problem pretty regularly. looks like axial needs to beef up their driveshaft connections |
11-07-2009, 11:37 PM | #8 |
Rock Crawler Join Date: Sep 2008 Location: Portland
Yes, we all have had that problem at one time or another. Blue lock tight and overnight drying will work wonders.
11-08-2009, 08:59 AM | #9 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
| I wouldn't blame it on Axial, I've had the same issues in my Willys outta my Punisher Shafts from RC4WD. A lil thread locker and no more problem. I put thread locker on my SCX-10 when I built it and haven't had a problem. |
11-08-2009, 09:18 AM | #10 |
I wanna be Dave Join Date: Aug 2007 Location: *
11-08-2009, 09:57 AM | #11 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
I actually pondered putting holes through the output shafts and using Traxxas style driveshaft pins, as the are designed to go all the way through the output shaft. But, I am lazy, and cheap, and decided to just get some loc-tite and go to town. Works well enough, but if you want something a little more permament, that is your alteranative.
11-08-2009, 10:46 AM | #12 |
Rock Stacker Join Date: Jul 2009 Location: ogden
well i had the same problem so i used blue lock tight but get rid of the steel set scwew and get a stanless steel replacement on both drive shafts because they strip very easly
11-08-2009, 10:47 AM | #13 |
242 loctite, alright heading to the store now, ill post up the results!
11-08-2009, 12:47 PM | #14 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
A word to the wise when using metal screws in metal parts is to always use loctite 242 blue. It's not an option but a necessity.
11-08-2009, 01:06 PM | #15 | ||
11-08-2009, 07:25 PM | #16 |
if they are stripped out you can use the next standard size up from the wrench you are you using now, use 2 grub screws PER yolk and loctight
11-08-2009, 07:43 PM | #17 |
RCC Addict Join Date: Jul 2006 Location: barstow
along with the blue loctite i have always added a second set screw to the other side since it is threaded between our 6 or 7 trucks i haver never had any come loose
11-08-2009, 07:47 PM | #18 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
I also run 2 set screws. I upgraded to RobinsonRacings hardened diff also.
11-08-2009, 09:40 PM | #19 |
Newbie Join Date: Jun 2008 Location: New Brighton
| Here is what I did to fix the same issue.
Here is what I did to fix the same issue. First I made sure that the shaft was clean and that it was on the flat spot of the shaft, then I bought two extra set screws so that there were two on each end of the shaft, it might be best to get all new set screws and the ones you have are probably smoothed out making them slip off easier. I also purchased the Axial driveshaft rings and installed them on both ends of each driveshaft. I have not had a single problem after I did this. Here is a link for the Axial driveshaft rings. http://www.axialracing.com/ftp/ax305...haft_ring.html You can also get the driveshaft rings from 3racing, Integy, and I am sure there are other companies out there selling them. They run around 7 bucks for two of them. Otherwise you could get the MIP CVD's, I have one set of those, best product out there if you have the money. For a little money you can fix your issues alot cheaper using the driveshaft rings. --John |
11-09-2009, 12:11 AM | #20 |
i used permatex 24200, which was said to be the equivalent at o'reilys so we will see how it holds up!
