11-15-2009, 10:29 PM | #1 |
Newbie Join Date: Jun 2009 Location: qualicum Beach B.C
| Tamiya bronco on scx 10 TR build
Just had to try and fit the Tamiya Bronco on the scx TR . I hated to do it but I had to cut 2 inches off the frame and then the frame seemed the right lenght. I used axial aluminum blue and silver rods to bilud the links to the right lenghth. I used the bumper lights to make the lights work on the Tamiya body and then hooked it through a hpi light control and to a button on my 4pk for a on and off light control. I used the proline shocks at the 95mm setting and I can not believe the difference . Even though it is shorter iit crawls unbelievably well and the shock rate is perfect; since the truck is 2 inches shorter the prolines are a must with the softer spring rate to get the suspension working. The drive shafts had to be cut and there is no binding at all. All the frame crossmembers are removed and I used blue aluminum ones locktited on just a tiny bit loose to give the frame just a little flex as well. I still want a winch and a few other things but for now Iam very impressed with the trucks ability. coming from comp rigs i never thought i would get this stability. The bumpers are lifted on the chassis and the front wheels are wieghted and i run the battery in the rear. Proline shocks are awesome this rig crawls with more control and better over all than when it was longer with the same wheels. Its running a Novak rooster with the 55 turn and a 17t pinion. Last edited by carver88; 11-18-2009 at 05:17 PM. |
11-15-2009, 10:29 PM | #2 |
oh yhea the wippers are from a hpi cup racer
11-15-2009, 10:49 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: Calgary
The body looks wicked gloss black, the silver trim pieces really stand out now. Great looking rig and welcome to RCC!
11-16-2009, 02:17 AM | #4 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
great looking rig did you cut it in the front or back ?
11-16-2009, 10:18 PM | #5 |
I cut the front and the back. I marked it out carefully and used a hack saw. I took 2/3 of the lenght off of the back. Mainly beacause the rear shock mount moves forward to the exsisting holes in the chassis so the rear wheels end up quite a bit further forward.
11-17-2009, 04:37 AM | #6 |
Rock Stacker Join Date: Sep 2009 Location: Hopkins
Looks nice, love that body and its detail. Props for cutting/hacking up your frame, I was on the fence about this body as well, glad to see it done already, helps with my decision.
11-17-2009, 09:20 AM | #7 |
It was a hard decision to cut the frame but once it was done I had to make it work. I will be limited to short bodies but I think this one will stay a bronco.I used a fair bit of wieght in the front tires 7 ounces per tire and then I ran the radio and battery in the rear and this combination makes it stick very well. The proline shocks made the whole thing work i did not like the way it transfered weight with the stock shocks, it was too stiff and not smooth enough for the short lenght.
11-17-2009, 11:31 AM | #8 |
I joined the Band! Join Date: May 2009 Location: anaheim
Damn thats awesome!
11-18-2009, 08:07 PM | #9 |
Newbie Join Date: Aug 2009 Location: newbedford
never seen one like this nice going |
11-21-2009, 05:24 AM | #10 |
Newbie Join Date: Nov 2009 Location: Qualicum Beach B.C. Canada
Wow you went all out with this one Jeremy lights and all. Like the tires too, but how will it stand up to the full size real thing? Gotta love the lines of the early broncos! |
11-21-2009, 05:57 AM | #11 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
Damn that this is beautiful!!!
11-21-2009, 10:05 AM | #12 |
Pebble Pounder Join Date: Nov 2009 Location: eastside of the 808
Very nice! Makes we want to reconsider my build.
11-21-2009, 11:26 AM | #13 |
Rock Crawler Join Date: Apr 2009 Location: Great Falls
It looks great. Do you have any body off pics?? I have the same body and want to do the same thing.
11-21-2009, 11:32 PM | #14 |
Newbie Join Date: Sep 2009 Location: Misawa AB, Japan
| Frame chop and link dimensions?
Awesome Bronco! I don't mean to steal your thunder, but I'm building a bronco as well. I do have a few questions for you (I'm a newb and I didn't really think about the frame to body length ratio). How much did you shave off of the frame? How long are your links now? Do you have any hind sight tips? Chris |
11-21-2009, 11:34 PM | #15 |
11-21-2009, 11:46 PM | #16 | |
11-21-2009, 11:52 PM | #17 |
| reply
Thanks man!! Wow, zero torque twist? And you didn't even have to reverse build the tranny? awesome! My AX-10 twists something aweful... still waiting on some upgrades on that one as well... damn postal system! I'll definitely be referencing back to this post during my build! Now if the post office could HURRY UP! Chris |
11-23-2009, 11:16 AM | #18 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Hey Big78..I can see your wife rolling that right now!!! but that's why we build em.... Good looking rig. I have found that running the battery in the back makes the truck want to flip when climbing..do you have that as well??? I am very supprised how the SCX's climb...even with 1.9's they stay up with my 2.2. |
11-23-2009, 01:32 PM | #19 | |
11-23-2009, 02:31 PM | #20 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Deep, glossy black. That looks excellent. It would look even better with some 1.9's, but thats just my opinion. Tamiya's early Bronco looks way more detailed than the HPI version I've had in the past. Are they the same dimensions? It'd be nice if these were a bit smaller... |
