| | #1 |
| Quarry Creeper ![]() Join Date: Mar 2006 Location: Howell
| Couple Quick Probably Stupid ?'s. Does the SCX10 come with straight axle adapters in the rear?, or is it locked out by the little plastic tie rods? [like the ax10] Are the hexes for the wheels 12mm or is it smaller being a 1.9 wheel? Looking to get one, searched, just haven't seen these answers yet. And need to get a good order together to make the first build worth while. |
| Sponsored Links | |
| | #2 |
| Rock Crawler ![]() Join Date: Sep 2008 Location: Delta B.C.
| it has the rear lockout, and it uses standard 12mm hexs as do all 1.9,s |
| | #3 |
| Really? ![]() Join Date: Dec 2007 Location: MT & ND
| The SCX10 kit comes with plastic rear straight axle adapters and aluminum 12mm hexes;) Edit... vonclod beat me to it Last edited by montana.matt; 11-17-2009 at 09:08 PM. Reason: vonclod beat me to it |
| | #4 |
| I like to #*&^ ![]() Join Date: Mar 2009 Location: sittin in the sky
| if you get the kit you will have to buy ALL electronics, which can be good becasue you can pick what suits you and what you like, i think youd like a 35t motor in it with stock gearing and a battery like 8.4 volts and it'll do whatever you want it to! have fun with it! |
| | #5 |
| Thanx for all three responces. The 35t was what I wanted and 8.4 is what I have. I'll be on it soon. Tubes will welded for a chassis. |
| Thread Tools | |
| Display Modes | |
